Question about Acer Aspire 5610-4648 Notebook
Reinstalling Vista and Acer Tech Cont.
I have an additional question to the one I wrote before about trying to wipe clean my computer-- I searched through the manual that came with my Acer laptop. There was a section that talked about reinstalling the software that came with the computer without recovery disks. It said to press F2 at startup and check to see if the Disk to Disk recovery was enabled (which it was). Then when the computer restarts press Alt+F10 at the Acer logo startup screen. I pressed it and either get repeated loud beeping noises or I got an imput screen that has information that looks like this: note all backslashes from "edit" to "HD" are reversed-- idk how to type them:
Edit Windows boot option for: Microsoft Windows Vista
Path: /Windows/system32/winload.exe
Partition: 2
Hard Disk: 66306936
[ /NOEXECUTE=OPTIN]
Is there any way I can use this to restart my system from the default settings when the ALT F10 only gives me this screen?
  • tjr3003 Feb 11, 2009
    I'm hoping that I can get a copy of the Windows Vista Home Premium and just reinstall it with that cd. Thanks for all the help!
  • 596 Answers
I contacted you earlier about this. Sorry for the delay. You can use the information to recovery your hard drive if you have encrypted the volume by using BitLocker Drive Encryption and you know the password. To be honest, I have only seen this error in enterprise version of Vista, Server and 64-bit os and most of the time, I have ended up having to reinstall the os from a cd because the disk was too damaged to recover the data.
If you need more information about this, here is a link.
http://support.microsoft.com/kb/928201 I do hope this can help you. Hopefully another IT pro has encountered this one and could shed some experience on it. Good luck.
Posted on Feb 10, 2009
    Problem Solver:
  • 9 Answers
Boot from a windows vista dvd, choose language click ok, then at then choose repair option, from there you may choose complete recovery option which will reinstall vista or to repair startup options
Hi, I have an Acer Aspire 5536 laptop with Vista which does not boot. I have tried rebooting a number of times, also I have tried to boot in Safe Mode and it just turns off after selecting Safe Mode. I...
I have had a lot of luck with Puppy Linux. Download the ISO, burn it to a CD using ISO burning software, then boot into the CD. From there, you should be able to browse your HDD and copy any files you want to a USB drive. I would suggest wiping and reinstalling your operating system after that.
Mar 01, 2011 | Acer Aspire 5536-5224 Notebook
When booting up,operating system not found. Using Acer Aspire 5536. Vista. Help!!!
That means the start up files on your computer are already corrupted. You may need to reinstall the operating system. You need an operating system disc for this to work.
Warning: Reinstalling the operating will wipe out everything on the hard drive, so if you need some help in backing up your files, either buy an external enclosure and back up the data on your other computer, or contact a local technician.
Here's the visual step by step guide:
http://www.theeldergeek.com/vista/vista_clean_installation.html
For your laptop's driver go to : support.acer.com
Feb 24, 2011 | Computers & Internet
I had windows vista .my webcam was working.now i changed my windows to windows seven but my webcam is not working .i even cont finde the folder or shortcut to open it.
Thank you for your post. After researching your webcam, I don't see any available driver updates from Acer; and Windows 7 compatibility doesn't list this webcam as compatible as seen HERE. You can, however, try installing the Vista driver to see if it may work. There are no guarantees to this method though.http://www.microsoft.com/windows/compatibility/windows-7/en-us/Search.aspx?type=Hardware&s=acer%20crystal%20eye%20webcam
Jan 14, 2011 | Acer Crystal Eye webcam
Problem Event Name: APPCRASH Application Name: godfather2.exe Application Version: 1.0.764.0 Application Timestamp: 497ecdfe Fault Module Name: godfather2.exe Fault Module Version: 1.0.764.0 Fault...
If you are running Windows Vista, this is solved quite easily:
Instead of doubleclicking the shortcut and running the program, right-click it and select: run as administrator. Now it should run fine.
On XP, try reinstalling the game.
I hope this helps,
Yannick.
Jun 17, 2009 | Acer Aspire 5610-4648 Notebook
I want to download acer empowering technology for acer aspire 5738-6922 with Vista Ultimate 64Bit (thanks from Brazil)
Another issue of simply reinstalling whatever you wipe out by going to the Acer location in which this resides, and downloading the original package, then reinstalling it. No big secret; just do what you need to do, and get it done.
Jun 05, 2009 | Computers & Internet
The restore disk should be available from Acer Suppport here https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer if they no longer support it then you should be able to get it from restoredisks.com
Feb 08, 2009 | Acer Aspire 5610-4648 Notebook
Multiple questions
well mybe your system slow for the fallowing reasons your brother never cleans his cache two try a disk scan and a defrag three reboot your system the nice things about these pc is that you have the option to reboot to factory condittions I have the same pc and I have not kind of slowing issues with it but please this computer is made for vista only not xp cuse you wireless will not work with xp hope this helps if you need help rebootin let me know you can email me at boricua7560@aol.com thanks bye luis
Jul 12, 2008 | Acer Aspire 5520-5908 Notebook
Acer Aspire E560 Home Basic Vista 512mb
yes, that's why with new computers, it comes with high ram.
In any case, try to clean out your C: do a disk clean up.
remove useless software. Don't archive for faster search (slow computer down)
May 12, 2008 | Computers & Internet
Acer 5610z will not start
I had the same problem with my neices Acer 5100...Went into safe mode, it loaded the drivers and sat that for what seemed forever...almost like it was hung up....I had a few things to do...and a couple hours later, it finally booted into safe mode.
I was able to save her files, but ultimatly ended up wiping everything out because of the corrupt files.
On another Acer, the same hang up "unable to boot into safe mode" even after a long period of time, and that Acer was a total loss..had to format...
I presume nothing was saved to a CD? i.e. her gsce files?
Doing a factory restore/reset will loose everything.
Try to boot into safe mode and allow it to boot up...see if it eventually comes up...I will keep reading for a solution other than the two here...and will post as soon as I find one...
Unfortunately, Acer do not have a good fix for most of their computer problems....
~~Jasta~~
Mar 29, 2008 | Acer Aspire 5610 Notebook
Will not run
the better choice you have is uninstalling it and reinstalling it again.
you may have a corrpted program file, or corrupted program info in registry.
both impossible to track manually, then i advise you to full reinstall it.
Nov 30, 2007 | Webroot Spy Sweeper (spysweeper) for PC
Acer Aspire 5610-4648 Notebook Logo
295 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
