Question about Whirlpool Kitchen Ranges
Whirlpool range electric
Top oven element works bottom element dont replaced bottom element no broken or burned wires
5 Suggested Answers
  • 1894 Answers
SOURCE: Oven doesn't work
http://www.repairfaq.org/sam/micfaq.htm
see if this site is helpful for you
Posted on Dec 25, 2007
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
  • 63 Answers
SOURCE: The heating element on the bottom of the oven does not work.
lots of those old elements are still out there...some come out with simple pull...or two screws holding the wires!.. take to appliance store (sometimes even lowes!)
Posted on Mar 16, 2009
SOURCE: Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Posted on May 26, 2009
iwillfixforu
  • 619 Answers
SOURCE: Broken Glass on Cooktop
Ouch. The glass top does have to be replaced but I just ran the partial model number on your range and if you're at the comp. I hope you are sitting down. Replacing it not bad. Purchasing tho is rediculous. Retail suggested price just for the top is 600.00. Rediculous pricing but GE is like that sometimes. Sorry but repairing the glass is not possible and getting it from a glass shop isn't either. Sorry for the not so good news. Rick
Posted on Mar 01, 2010
Whirlpool oven dony heat up to the temperture
You likely have an oven element that is burned out. The elements can be replaced. Determine which element is burned out and put your hand near the element with the door open to see if if is the bottom or top element that is burned out. Then go on the web to an appliance part sales company such as appliance parts.com. Enter your Whirlpool model number and do a search for heating elements.
Order one. When it comes, turn off the power to your oven. (go to your house power panel and turn off the breakers that feed the oven.) Back to the oven. Open the oven door and look at where the element comes out of the oven wall. Undo the two screws, pull the element out through the two holes in the oven wall an inch or two. If you find insulation coming out with the wires, push the insulation back into the hole so you can just see the attaching electrical wires. Find attached to the old heating element a electrical wire connector with wire going back on of sight into the hole in the oven cabinet, one for each element end. Unplug the connector. You may need pliers to wiggle it while pulling off. Reverse the installation. Plug the connectors on to the ends of the new element. Reinstall the two screws that hold the element to the wall. Turn the power back on to your oven. Give it a try. It should work and is the most common reason why your oven would not get up to temperature. Likely one of your two elements is burned out.
Nov 04, 2014 | Whirlpool WFE510S0AS 30" Freestanding...
My ge jtp56woa1ww double electric oven will not bake in the top oven. broiler in the top oven seam fine. Lower oven functions great in both features. What to do?
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
Oct 08, 2010 | GE Profile JTP56 Electric Double Oven
Whirlpool RF302BXYW Ser# FD1227461 oven quit working (surface burners are okay)
Several possibilities:
1: Fuses blew under the top cover. Oven fuses will not affect top burners.
2: Element has burned out. Top element only heats when you try to warm the oven.
3: controller has burned out. A controller can cost $150 - $600 for digital. You might want a tech to confirm before you change this one.
Apr 17, 2010 | Whirlpool RF302 Electric Kitchen Range
My oven is two years old and the bottom oven coil will not heat up. The top one works just fine but not the bottom.
you may have a burned out bake element even if the range is only a couple of years old. if you can see the element look for a burned area. if you can't see it you will need to unplug the range and see how to get it out yourself or call a repair service. hope this helps.
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven Element and Broil both do not heat
you should have 220v between the two terminals of the elements, either the switch is broken or a contact is burned or a feed wire is broken to the switch, check wire diagram and carefully analyze the system while it is "hot" ie... energized
Sep 17, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Bottom burner in oven dose not work but top burner work why
Hello, The wire going to the bake element could be burned in two. Pull the range out and take the back off ( make sure you unplug it)., check the wire going to the bake element for any shorted, burned, or broken spots. The wire will lead all the way to the thermostat on the control panel. If the wire is good, you have a bad thermostat. The thermostat part number is.
part # 74005019 price $98.97
This part is listed as NO LONGER AVAILABLE at the manufacturer so you should really get one as fast as you can, or it will be gone for good. I hope this will help.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Dec 02, 2008 | Crosley CE35100AA Electric Kitchen Range
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 Catriver..post back.
Apr 21, 2007 | Whirlpool RF369LXPQ Electric Kitchen Range
Kitchen Ranges Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
