Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Noisy on rugs!
On my hard flooring and even carpeted rooms, the Dyson Animal Bagless works perfectly, but push it on any of my area rugs over the hard flooring and it sounds off like a buzz saw!! This sound continues on the rugs until either turned off or placed fully upright.
My mother has the same issue on her rugs with her Dyson. I have to use the attachments when doing my rugs just to avoid this startling/nervewracking noise! It would be so much easier to just push the vac. over the rug and be done with it.
What is the problem and how do I fix it?
  • Anonymous Mar 31, 2014
    it doesn't seem to be rolling properly, I washed out the filter in the ball area and still having issues. Hard to push on hardwood floors and not picking up very well.
  • 3,037 Answers
Are the rugs long haired or short haired? Most likely the suction is just causing the noise when it picks up the rug and the buzz saw could be the beater bar hitting the rug then. I actually own a DC14 and it does the same thing and the rugs like to be dragged along. Nothing really to fix this, just the way it is. You could try it with the beater bar raised and see how well it works then but this sounds normal.
Have a good day
bestdarngood
Posted on Feb 10, 2009
I have a huge area rug, I cannot even push the vacuum because it sucks up the rug. what can I do?
This vacuum is not made for the new soft carpets
only special vacuums are recommended by the rug Manf, Emer Vacuums USA
Here is a link for these vacuums
Jun 28, 2015 | Dyson DC28 Animal Bagless Upright Vacuum
Why am I unable to push vacuum forward on new area rug. But will work pulling backward. Works fine on old rugs and floor
It might be that the new rug has a backing that is not as stiff a the other rugs which can cause a rug to bunch up making it hard to push the vacuum forward.
Feb 23, 2015 | Dyson DC25 Animal Upright Ball Bagless...
Cannot push vacuum forward on new area rug. But will work pulling backward. Still works on old area rugs and floors.
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your DC25 on this particular new area rug. As you've confirmed the vacuum works as normal on other rugs and hard floors, it doesn't sound like there's a fault with the vacuum itself.
As lightweight area rugs are not fixed to the floor, it's possible for the rug to lift and seal against the soleplate of the cleaner head, due to your DC25's powerful suction. As this will reduce the amount of airflow entering the cleaner head, you may need to use more push force than usual when vacuuming this type of flooring.
We would encourage you to check directly with the rug manufacturer, as they'll be best placed to provide information on correctly caring for this particular floor type.
If you'd like to discuss the issue you're experiencing with our experts, you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
I can't push my Dyson Dc33 on my new carpet..it works backwards ok but not pushing forward?
Hi Fran, it's Jack at Dyson.
DC33 is engineered to work effectively on both hard and carpeted flooring. The cleaner head is engineered to adjust automatically for different floor types and carpet piles. You can also turn off the brush bar for hard floors and delicate rugs, using the brush control on the cleaner head.
I'm sorry to hear you're having difficulty pushing your machine forward on this particular type of new carpeting. If your DC33 worked effectively before the new carpeting was fitted, it doesn't sound like there's an issue with the vacuum itself. However, we'd appreciate the opportunity to take some further details about the issue, and may be able to suggest a resolution. You may also want to consider contacting the carpeting manufacturer directly, as they should be able to recommend the best way of caring for this specific carpeting.
When you have your DC33 easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 13, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
The Dyson DC25 grips new carpet. How can I adjust the brush height
Like most Dyson upright vacuums, DC25 is engineered to adjust automatically to different carpet piles, without stopping to adjust any fiddly levers or dials. You can also turn the rotating brush bar off to clean hard floors and delicate rugs - just press the silver brush control switch next to the red on/off switch.
If you're having difficulty using your DC25 on a particular type of new carpeting, we'd recommend checking directly with the carpet manufacturer for their advice. They should be able to recommend the best way of caring for this flooring.
For any additional assistance from our experts, you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 10, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
We love our Dyson DC25 Animal but we just got new carpet and it's like pushing furniture around the room. I know it doesn't have a height adjustment but is there any other option?
I'm sorry to hear you're having difficulty using your DC25 Animal on this particular type of carpeting. This sounds unusual especially as it worked effectively on your older carpeting. As DC25 is engineered to adjust automatically to different floor types and pile heights, there is unlikely to be an issue with the vacuum itself.
It may be worth checking directly with the carpet manufacturer for their guidance on caring for this specific type of flooring. Manufacturers will sometimes recommend vacuuming certain types of long-pile or delicate carpeting with the motorised brush bar turned off.
If you'd like any further guidance from our experts, you can reach us by calling the Dyson Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 11, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
Extremely difficult pushing vacuum over new carpet
Hi Julie,
I'm sorry to hear you're having difficulty using your DC17 on this particular carpet type. I'd encourage you to contact the carpeting manufacturer for advice, as they should be able to recommend the best way of cleaning it.
If you'd like any further assistance with your machine, please email us on askdysonUS@dyson.com, or give our customer Helpline a call on 1-866-693-9766.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 09, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
Terrible noise when I vacuum some of my carpets
That is the clutch you are hearing and what it is doing is jamming up. Check for anything jammed in the brush, if not you may need to take it in for service to have that replaced or the object is lodged in the clutch itself.
Dec 16, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Loud noise
This is the clutch as it jams up in the brush. Usually happens with rugs that are not secured to the floor.
Dec 11, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
236 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
