Question about Hitachi 51F59 51" HDTV Projection Television
Hitachi HDTV "no sound" or "no audio" OTA channels *SOLUTION*
I am actually just posting this, for anyone else searching for OTA audio issues on *some* (not all) HD broadcasts:
Check your TV settings for the firmware version. For a Hitachi 50VS69A / 55VS69A / 62VS69A, this is found from the remote: "Menu-->Setup-->Reset the Software". The MMC version will be something like v.0102.0001.
As of now, Feb 2009, I just upgraded to v.0109.0001.
You will have to go to the Hitachi website and email their tech support. They will send an MMC card, instructions, and a return envelope. You put the card in the back of the TV, turn it on, drill back down the menu, and select to upgrade. After that, you unplug the TV, remove the card and send it back to the Hitachi mothership.
Also, in my search to find a solution, I found only one post somewhere, which mentioned upgrading the firmware--something I would have never thought to do on a television. So, I'm throwing another post out here, in the hopes that the idea helps someone else.
Peace.
  • 4,234 Answers
Thank you for posting this. I will attempt to post this information in a more permanent place that can be found easily.
Thanks again,
Dan
Posted on Feb 10, 2009
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Cannot get audio on one channel
Which make/model TV do you have? Are you watching an OTA signal or cable signal?
On my Viewsonic N1930W, I had a period where certain OTA VHF channels had no audio. The UHF channels were fine. The steps I used to reset the TV: unplug for a while. After reconnecting the power, go to the Tools (Options) menu and then reset the TV to the defaults. Then I did a new channel scan for OTA channels. On my TV, the menu is called Options but the icon is a wrench and a hammer in an X. Thus I call it Tools. The Restore Default option is at the bottom of the list in that menu. The reset command triggers several "Are you sure prompts?" Pressing the Enter key on the remote after highlighting Yes is required. After the reset, I can go to the Channel menu and select Auto Scan after making sure that it is set for Air as the source.
If you post a comment with the details of your TV, I may be able to give the steps to reset your TV.
I hope this helps.
(I spent several days trying different solutions and did e-mail Viewsonic support on the problem.)
Jan 05, 2013 | Televison & Video
P50s601 sound issue
The model number indicates a Hitachi Plasma (correct?)
If buzz etc one channel is having a problem (not likely the speaker as you have discovered)
RCA HAS A OLDER SET WITH SAME MODEL NUMBER.
Means the left channel in the audio output is defective--If you Google the model number with "service manual" you should be able to find a schematic which will tell you if a single chip is used for both channels for output (this is usual case).
With that information either the chip or the board it is located on should be able to be repaired or replaced outright.
PTS ELECTRONICS DOES REPAIR BOARDS WITH ISSUES LIKE THIS (national company) in case you cannot locate either the part or the complete board.
Hitachi customer service may also be of help if you contact them--one channel low, buzz etc almost always is in output circuit of the audio.
Mar 26, 2012 | Hitachi Ultravision P50S601 50 in. Plasma...
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
I am trying to upgrade firmware on a hitachi 42hds69, using a 2 sd card, I formatted the new card before uploading the file, I did unzip the file on my desktop. The tv won't do the upgrade. any Ideas
I had an issue (OTA no audio in channel 2-1 and 11-1) on my Hitachi 42HDS69 so I tried to upgrade the firmware. The manual as well as the instructions on TV all state to use a MMC card. Someone on an internet forum also stated that a 7-pin MMC is needed. I tried exactly that but it did not work. Finally I tried a 128MB SD card and it worked like a charm. The firmware upgrade fixed my OTA audio issue. I went from V0108 to V0125.
All you need to do is to extract out the .F02 file and place it in the root directory of the SD card.
BTW, I did call Hitachi customer support. They refused to help due to the TV is too old (about 10 years old).
I guess it all depends on who you speak to at Hitachi?!
Feb 09, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have just been given a hitachi AX-M76 hifi system the only problem is it is missing the control lead, can anyone suggest where i can get a replacement
Found a "System Cable" for the Hitachi AXM76!
It's at 'Currys Partmaster' for £12.99p plus post!
When you get to the site enter "Hitachi AXM76" and it will show you a picture of it. Would have posted the picture on here, but the Curry's site won't let me!
http://www.partmaster.co.uk/cgi-bin/search.pl?query=Hitachi+AXM76&frmSFinder_headerSubmit=Search
See if the link works first!
May 29, 2010 | Audio Players & Recorders
Help I cannot get any tv channels on mo lg 32 combo
What is your TV source? If you are looking for OTA (over the air) signals, you may need to modify your antenna setup. An external antenna rotated to the correct direction usually works best. See antennaweb.org and tvfool.com for details of what stations you may receive OTA. Antennaweb is much more conservative in the channel availability list than TVfool is. On both sites, enter your street adress for the details.
If you had a recent surge through your antenna, then you may have to repair/replace the TV tuner. (My household lost three CRT TVafter a nearby lightning strike.)
(Antennaweb.org lists only my area as only getting 2 channels with an external antenna (one transmitter source - 10 miles away). We actually get more - the other channels are transmitted from ~30 miles away.)
Jan 01, 2010 | LG 32LG40 32 in. LCD HDTV
Hitachi P50H401 display problem
it is problem your TV high voltage unite(EHT)
change it by authorised service centre
Aug 28, 2009 | Hitachi P50H401 50 in. Plasma HDTV
No sound on one channel
check your remote for a a audio button alot of times certain channels like PBS only plays in one sound It will be the button that changes the Mono/Sap/Main settings for audio or it could be a issue that network is having
Apr 28, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Tv guide/tuner problems
Most likely the TV Guide is broadcast from the OTA PBS channel. I don't know why its being lost. I'm thinking its probably a firmware problem of some sort. Adding the PBS channel back in, making sure the signal comes in ok and leaving the TV off for a while might help.
Dec 25, 2007 | LG 26LX1D 26 in. LCD HDTV
Hitachi 51F59 51" HDTV Projection Television Logo
1,130 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
