Question about Kyocera Mita FS 3800 Laser Printer
Printer will not work
My printer gave me the message to check the ink waste bottle. I did just that and emptied the bottle and replaced in machine. now my printer will not work it keeps saying to check the waste bottle. I have taken it out at least 20 times and replaced it and it still does not work. What can I do?
  • Tditty Apr 14, 2008
    I have cleaned out the waste toner bottle and replaced it, turned the printer off and then on after 10 seconds to reset, still says "Check waste toner bottle". Any suggestions?
  • 98 Answers
Check this forum : http://www.fixyourownprinter.com/forums/laser/37421
Posted on Aug 02, 2007
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
My printer, epson stylus R230, shows this message ' Parts inside your printer are at the end of their service life. See your printer documentation. ' How can I solve this problem?
You need to reset your printer. Google search for "indoreset for r230", that is the program that you can use to reset your printer. Or you can use the SSC Service Utility, just search for it in the net. You particularly need to reset the waste ink pad counter.
After you reset your printer, check the back of your r230, you will see there a small access cover with a screw. Unscrew it. Take a look inside and you will see a tube connected to the waste ink tank, try to disconnect it from the waste ink tank, carefully pulling it out the access window. Do not force it out completely, you will be able to pull out only about an inch of the tube. When the tube is out, get another tube (silicon or plastic) around 6 inches long would do (12 inches will be fine)that would fit in that tube you've just pulled out, then get an empty plastic bottle with a cover, puncture a hole in the cover and put the other end of the tube in that hole, that plastic bottle will be your new waste ink tank. You are doing all these so you don't have to dismantle your printer to remove and replace the waste ink pads inside.
After doing all these you can now use your printer again. You just need to empty the plastic bottle regularly. And when the time comes to reset your printer again, just use the program again and that's it.
Aug 27, 2010 | Epson STYLUS R230 InkJet Photo Printer
Waste toner is almost full on Ricoh aficio AP3800C
Open the main front cover and you will see the white plastic waste toner bottle on the left hand side halfway up. I lies on its side and you can see the bottom of it.
Slide it out gently keeping it level to avoid spilling all the waste toner.
Either replace with a fresh empty waste bottle or empty the bottle into a large plastic bag you can keep sealed with the bottle inside while you shake it.
You have a good chance of spilling the toner all over your clothes if you are not carefull and note that the waste toner IS HIGHLY INFLAMMABLE so no naked flames nearby!!
Jul 25, 2009 | Ricoh Aficio AP3800C Laser Printer
Waste tonner tank
The waste toner container is inside the front cover at the bottom right. If you work for a business you should purchase a new one. If not you may be able to empty it into a another container and seal it before putting into the bin.
Jun 29, 2009 | Samsung CLP-510 Laser Printer
I ahve a Ricoh Aficio mp c1500 printer and I have the message the waste ink tank is full
there is a waste toner bottle inside your machine, you have to empty it and put it back, if u have new one replace it.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Apr 17, 2009 | Office Equipment & Supplies
Waste ink near full
This page gave me a solution worked for me: http://www.inkjethelper.com/inkjetstuff11.html
Mar 23, 2009 | HP LP LPQ1200 Matrix Printer
Waste ink tank removal
ok
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 18, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Kyocera Mita FS 3800 Laser Printer Logo
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
