Question about Philips HTS3450 System
I own an hts3450 system, dvd player part is destroyed.
Where can i buy the dvd player part? Or, what other unit can be hooked up using the same subwoofer/amp connection
    Scholar:
  • 144 Answers
You can check on ebay if maybe somebody else has damaged set. they seem to be sold a lot there. Otherwise contact philips vendor
Posted on Apr 17, 2009
My question is. . Is it possible to use a philips HTS3450 surround sound system without the blueray player?
Depends on how you intend to hook it up otherwise you will get no sound from the speakers if you delete the DVD player from the circuit. The speakers require a power source and this is provided via the DVD player.
You cannot connect those speakers up to an amplifier or an AV Receiver because the speaker connections are not compatible. The connections to the speaker wire where they plug into the DVD player would have to be changed because there needs to be a left and right wiring connection for each speaker.
So if I were you I would not mess with the system and just route everything via the DVD as it is designed to be done.
Dec 26, 2015 | Philips Audio Players & Recorders
Model No. PWR2006-37. Where can I buy a power supply?
Before rushing off to buy a replacement power supply, open your sub and check for a blown fuse.
Sep 01, 2015 | Philips Hts3450 5.1 Channel Home Theater...
I have the home theater system model HTS3440/37. I've had this for a couple of years, and now all of a sudden, it won't read any discs. It comes up after a couple of seconds and says "No Disc"....
Well, let's see.
A) A whole used HTS3440 is available on eBay for $102 delivered.
http://cgi.ebay.com/Philips-HTS-3440-Home-Theater-System-/150532939141?pt=Home_Theater_in_a_Box&hash=item230c765d85
B) A compatible HTS3450 base unit goes for $79 delivered...
http://cgi.ebay.com/Philips-HTS3450-HomeTheater-Receiver-HTS3450-37-/360338243552?pt=Home_Theater_in_a_Box&hash=item53e5d53fe0
C) Connect a new or existing outboard DVD/BluRay player to it.
Proprietary connectors usually imply proprietary function. Home Theater in a Box runs that way and are typically Not Economically Repairable.
Though it may be possible to construct cabling that adapts 'normal' standardized audio to your HTIB speakers, is it really worth it?
I'd got with option C as it would be a better investment in equipment with longevity and forward compatibility.
Feb 05, 2011 | Philips HTS3440/37 System
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
HTS3450/37 DVD player won't spin up to speed.
That is a common symptom of a depected Ribbon connector,you better replace it with identical rating in order to works normal again..
Hope it may helps you;;
Jun 08, 2009 | Philips HTS3450 System
Philips hts 3450 home theatre system, dvd in player, won't come
Before you do what I am about to suggest, understand that doing so will void your warranty with Philips. Find out if the product is still in warranty before proceeding - if it IS in warranty, then get it replaced through Philips (even though it is a simple solution):
Unscrew the four main screws on the bottom of the main base that are keeping the main unit together. Open up the case, retrieve the disc. Make sure that you do not knock ANYTHING out of place - you must proceed VERY carefully. Rescrew the case. Voila!
-Tha Mp3 Doctor
Dec 10, 2008 | Philips HTS3450 System
Hts 3450 home theatre system- dvd in player- but won't come out
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Philips HTS3450 sound problem
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jun 09, 2008 | Philips HTS3450 System
Philips HTS3450 System Logo
157 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
