Question about HP Officejet 5610 All-In-One InkJet Printer
How do I install the printer cartridges? What is the trick?
I looked at the diagram, but they don't want to click in...Someone, please help.
  • thompson_jea Feb 10, 2009
    I need a diagram on how to install the printer cartridges..Which way do they install
    Problem Solver:
  • 9 Answers
First check to remove the protective clear plastic from the cartridge, if it is already removed, take out the cartridge shake it a bit then get a piece of tissue with some rubbing alcohol and wipe the bottom of the cartridge.
Posted on Feb 10, 2009
  • Alfred Chin Feb 10, 2009
    go to this link and watch this video
If i want to print, my printer says chek printer and than 5100. If got a canon pixma mp170
Hi There
Please Do mention below trick to resolve your 5100Error.
  • Turn of your Printer and remove the all connected wired, open the door and checked any Paper Jam is there, because the Jam paper blocked the Ink Cartridge.
  • After try first if you get same error then remove the Installed Cartridge and put again at proper, may now you don't get any error for printing .
Thanks to Visit on Fixya
Oct 12, 2012 | Office Equipment & Supplies
Belt repair for lexmark p3150 print trio multi-function
If you need lexmark customer support number 1866-877-0191.We are always here with tech team for your help. For further Info Click On Me:
Mar 11, 2012 | Lexmark P3150 All-In-One InkJet Printer
Replaced the toner cartridge and unit will not recognize new cartridge
First Install the Printer Driver.
if the Printer Unable o Scan & show the Error -- There is no TWAIN-compliant device installed. Please Install one & try.
Then U Follw this Tricks.It will solve Ur Problem 100 %.
Click on Add devicesClick on Start - search on scanner word -- click on View scanners & cameras -- Next - Selcet Manufacture Name & select the Printer Device Nname - next - Fiinish.
Mar 08, 2012 | HP Laserjet M2727nf Multifunction Printer
Do I remove the metal strip on the printer cartridge before putting it in th eprinter?
Hi, There is a piece if tape to be taken off and then you can put it in the printer. The tape covers the print head for packing. Turn on your printer and open the cartridge bay and put it in the slot making sure the copper part meets the other copper part in printer. Then close cartridge bay door and your good to go.Note: The cartridge should snap in when installed correctly.
Nov 18, 2011 | Office Equipment & Supplies
Error on printer Connon ip 1000
Error code: 5600
Description: Cartridge displaced error
Symptom: blink in orange 9 times,beep 10 times
try removing and replacing the cartridge
please rate our help to keep the service online
Aug 24, 2009 | Epson Stylus Photo® R2400 InkJet Printer
I did find a procedure online to clear the memory and that did the
trick. Here it is, may help someone in the future:
Open lid, take both cartridges out. Physically remove the power cord from outlet or back of unit. While pressing the Stop/Clear button, plug cord back and kee pressing until a message saying "clearing memory" comes on. Reinstall ink. You're done, the message should go away.
May 03, 2009 | Lexmark X63 InkJet Printer
I installed a new Lexmark cartridge for printer 2400, it printed out test page and the cartridge is stuck on the left hand side of printer and will not work. The bulls eye diagram comes up says print...
Try doing "start", "control panel" then "click on printers & fax's", & when you get it open to the "icon" that shows your printer", right click on the printer in use icon, & you get the drop down menu", try clicking on "properties", you should get a "pop up box" with a line saying, "printer is busy", & maybe even written several times, click on & delete all of the lines, if that don't do it right away, turn off & unplug ur power cord until you hear a "noise from ur printer", this is "resetting & releasing it", (probabIy less then a minute, maybe even reboot the PC) printer will not print until you get rid of these "commands", I couldn't be more "precise", on getting the "box", to appear, as it will only "come down & appear", if ur having this problem, hope this helps....Don
Dec 03, 2008 | Lexmark Office Equipment & Supplies
Ink cartridges
Click on this link for cartridge installation instructions. There is also an animation link on this page.
PSC2210 Ink Cartridge Install
Make sure you use #56 (Black) and #57 (Tri-color) cartridges.
Nov 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
"incorrect color cartridge installed" message
I have the same problem and I am looking for a solution also. I stopped using the printer for some time and then purchased some refurbished cartridges and hooked it back up. Prior to this I never had a problem except for paper not feeding correctly from the top feeder. Anyway the way I was able to get around this was to send a fax, once the fax was completed the printer was ready. Of course someone turns it off etc I am back to the problem on start up. The fax trick no longer works for me but might work for someone else. If anyone has the solution please post it.
Sep 09, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
How do I install a new cartridge holder?
Click this link for a service manual free download for your multipass c2500 inkjet printer troubleshooting.
This will help you replace the holder.
If you cannot click just copy and paste the following link into your browser window.
Apr 30, 2008 | Canon MultiPASS C2500 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
24 people viewed this question
Ben Johnson
