Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Washing Machine agitates only
Have a Maytag Front Loader Washing Machine. The drum agitates but does not spin. Any help is appreciated.
  • kkatman Mar 03, 2009
    i have a maytag front loader washing machine the drum agitates but does not spin
    President:
  • 1,891 Answers
Ck the door interlock sw/ in the front of machine . ck for loose wiring and then the sw itself. either of these could cause the problem . hope this helps **** and thanks for ysing fix ya .
Posted on May 22, 2012
Maytag front loader washing machinne the drum agitates but does not spin
Posted on Mar 03, 2009
I have an older maytag front loader washing machine, during the spin cycle, it sounds like a jet engine taking off, need help with repair
Step#1 go to 'Sears Parts' find your make & model. This will provide you with a complete diagram. Problem sounds like #1 drum support rollers #2 drum seal rings #3 drum drive belt or #4 the drum drive motor or its spring supports. Open the machine housing were you will see inside Ops during noise will ID the problems location. CAUTION!!! Electricity can KILL & Mechanics will take a finger or arm with no questions asked. "You feelin lucky punk"
Apr 21, 2016 | Maytag Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
My maytag washer mav9501eww does not spin, but it drains and it does agitate
Not sure if this will help, but I had the exact same problem on a Maytag top loader. With the machine powered off, spin the wash drum clockwise with your hands. It should be very loose initially and then will tighten up. Unfortunately I don't know the exact mechanism that makes this work, but it did work for mine.
I hope this helps...good luck!
Feb 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
233 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
