Question about Philips 42PF9630A 42 in. Plasma Television
Can't get my sensor light to work, the light around my screen
Don't know how to turn the light on.
  • soberanis14 Feb 23, 2009
    no power and signsl
No power and signal
Posted on Feb 23, 2009
My two idiotlights don't come on when you turn key on and head lights don't work. have replaced ing. switch with no change
check for a fuse near the engine to tractor wiring connector. check battery cables for looseness & corrosion. tighten the ground cable where it connects to the chassis and inspect the engine to chassis bolts. loose connections can cause backfeed problems, such as when you step on the brake pedal in your car, and can then turn on the radio...
Dec 16, 2012 | Garden
I have a 2007 cadillac dts my problem is that my traction, abs, stabilitrak light keeps coming on. sometimes while im driving it will go off but as soon as i make a turn the lights come back on. this all...
This is the procedure when any light comes on your dash
By the way-- the same since 1983 some 31 years
You turn on the key-all lights come on the dash
Start engine they all go off --no faults with OBD2 System
Once a MIL Lamp,check lamp,ABS,trac,etc come on,you
check for codes that day or the next
Then you know if you should continue to drive until you have
an scheduled repair shop visit
You make every effort to have the vehicle diagnosed & ALL
things repaired,fix,whatever,once & done properly,the entire
car checked over ,complete within a week.
No driving around & asking what to do for weeks
Your car has faults that don't meet federal emission standards
or could cause damage. You don't know until it is checked out
I have no idea who told you to unplug a wheel speed sensor
or why your driving around knowing you have to make a repair
eventually,get it over with.
Someday-- such as a transmission issue-- driving 5 miles will
cost you 5 thousand
You have ABS System problems,Wheel Speed Sensor---Maybe!!
Oct 03, 2012 | 2007 Cadillac DTS Sedan
I have a Whirlpool Gold Conquest refrigerator model number GS6SHEXML00. It is working properly except when I open the fridge door, the light doesn't turn on. The freezer light turns on correctly. I...
George Andraws, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (George Andraws), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
The screen will not show the image. it looks as if the screen is cracked, but there is no crack on the screen. also the zoom will not go in or out. the camera turns on, you can hear it and the lights on...
firts resolve the lens issue
1.- Clean the lens surface with a soft cloth (clean the cilinder body of lens)
2.- Turn OFF the camera.
3.- Gently Push the lens
4.- Gently PULL the lens while you turn ON the camera
Check if the lens go in and out. If the lens don`t move try again step 2 to 4
If the lens move, and the Screen continue NOT image (screen is white) you need replace the lens sensor
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Kodak EasyShare Z650 Digital Camera
Pink lines on canon powershot a95 camera. also when in shooting mode, camera screen flashes- like it is trying to set light levels.
Sensor gone bad. Factory defect. Canon had recall about that a few years ago. A bunch of sensors produced by one of their suppliers (also used in other brands) turned out defective. They repaired my A95 (well past warranty) for free a couple of yeas ago when it developed that problem. Don't know it they still would. Contact them.
Aug 17, 2011 | Canon PowerShot A95 Digital Camera
My acer Aspire 3500 wont turn on. It was fine a few hours ago but now wont boot. I keep getting the acer picture featurning the f2 set up and then the screen turns blank with a white flashing - in the left...
if you activity lights on, try connecting to an external monitor or modern flat screen tv. if the screen is flashing then it is probably a screen issue. eg the invertor r screen has failed.
Jul 23, 2011 | Computers & Internet
When I turned on my PC, the blue light was on, but, the video screen was blank (Dark). I read the solutions in web site, they suggested to replace main board or RAM. Here, I don't know if it is worthy...
Hi, Turn off the computer and open the side cover by removing two screws. If you have a video card remove it and clean the connectors with alcohol and also the memory card connectors. Re install it and install it back the side cover and turn the power that should work for you. Get back to us if this information helps you solve the problem. Good day...
Jul 13, 2011 | Acer Aspire m5640 PC Desktop
My air bag light stays on all the time I did have some work done on my front bumper would this cause it will it cause any harm or does it mean the air bag is not fuctioning
See if they left the front sensor unplugged
Iook so disconnect the battery,wait a few minuites
then connect it,the SRS Light should go out
Or take it back to whom ever worked on it
The system may be turned off,don't know,
but I would want to know it was working
Jun 12, 2011 | 2000 Ford Taurus
Sears HE3 Dryer - "Check Lint Screen" light is on. I cleaned lint screen and area around screen but light will not extinguish and dryer will not turn on. I unplugged dryer for a time and plugged back in...
I am not familiar with your dryer, but it sounds like a safety mechanism where if your lint screen is not cleaned the dryer will not turn on. That "Check Lint Screen" light for your dryer may be connected to a sensor near the lint screen area. Check that out and see if that is the problem. If there is a sensor it could be faulty,
Apr 28, 2010 | Dryers
My door will not go down, I can't make the sensor turn green. It was working good and just stopped all at once. How do I know if I have a bad sensor or it is just out of alighnment?
you have to keep moving the sensors until the light stays on steady green not blinking. one is a sending the other is the receiver. If the lights are on steady green they should show an unbroken line of sight. I have a smiliar problem and have the sensors duct taped together with the green light on constantly and it still won't go down. but firts try and get the green lights to stay on...hope this helps don
Apr 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Philips 42PF9630A 42 in. Plasma Television Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
