Question about Marantz SR-18EX Receiver
On the Marantz SR-18 amp how do I switch the DSS setting from Dig 2 to Dig 3? Our sound is coming in on Dig 3 and somehow the setting got changed, probaly an errant command on the remote
    Scholar:
  • 93 Answers
You have to assign the digital inputs on the setup menu from the remote control while you have the On screen display on a monitor or TV screen.
Posted on Feb 11, 2009
I bought a second hand marantz receiver. my problem is when i push the cd button the display read like this: CD/DIG2/STEREO/NO DATA and the it will go back by it self to CD/DIG. what should i do? please...
the receiver is ok. it is telling you that CD is assigned to digital #2 input, surround mode is stereo and there is no input signal. You need to connect a source to digital2 input (coaxial or optical) and you'll get sound from it.
Jun 01, 2012 | Marantz SR-7000 Receiver
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Dec 23, 2007 | Marantz SR-18EX Receiver
No sound from TV
check the fuse output line in the speaker! or maybe you are in protect mode! checkout the speaker, maybe you have defective speaker, thats why your unit in protect mode, thats why no sounds coming out!
Oct 06, 2007 | Marantz SR-6300 Receiver
My sr 18 has no audio output,on all speakers,but video is good.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR-18EX-Receivers-manual/id/511ci766/t/2/
Headphones connected?
Disregarding specific sources, how does it do with test tones?
Jul 09, 2011 | Marantz SR-18EX Receiver
Hi, I have recently purchased an SR7005 which is connected to an HD PVR via Audioquest Cinammon HDMI cable. While watching programs, I lose audio immediately after an advertisement break. If I pause...
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
Jun 12, 2017 | Marantz SR7005 Receiver
I have a marantz sr7200 receiver and i am unable to get sound when its in DSS mode. The sound works in dvd and tuner modes.
In the setup menu, did you set up the input assignments for DSS to be the correct digital input or analog?
Feb 25, 2011 | Marantz Audio Players & Recorders
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
I need the remote control code numbers for the SR-18 so I can turn it on with my Direct TV remote.Do you know what they are?
the best thing to do is a code search per the directv manual and hope the Marantz powers off when you find the code.
If it turns off, you have won half the battle. Save the code and try turning the Mar back on.
The issue is that these universal satellite remotes are very limited on there funtionality with audio systems.
Keep in mind that if you find a code that turns it on & off, you will probably be limited volume only. If you get those three functions, you are very happy and call it done.
Hope this helps.
This goes for all sounds systems and not only Marantz.
Jan 19, 2010 | Marantz SR-18EX Receiver
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
Marantz SR-940
Just finish repairing Marantz SR 940 with no sound output. Problem was a clamped speakers relay located behind the speakers lugs (red and black post connectors). To reach the relays you must remove the little circuit board behind those colored connectors et unsolder the posts. There is 2 relays, one for A set and one for B set of speakers. Very EASY when you know the solution!!
Nov 24, 2008 | Audio Players & Recorders
Marantz SR-18EX Receiver Logo
231 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
