Question about Westinghouse LTV-32w4 32.02 in. LCD HDTV
TV power light comes on but no picture/no sound
Power switch will not turn TV off. Must unplug to shut off power light.
TV was playing with good picture and sound but began shutting off intermittently and now will not get picture or sound at all. I have power to my tv put no picture shows it. It almost seems to me that there isn't enough power getting to it to turn on. I had it fixed for like one day and then it just completely stopped working. The only good part is that it is still under warranty and I can get it fixed or get a new one with out having to drop a lot of money or any money at all. The only way I could get the tv to turn on was by the remote. The buttons on the side did nothing.
    Genius:
  • Westinghouse Master
  • 1,667 Answers
The control panel, or the circuit area that reads the control panel, or the uPC is not functioning properly for reading the control command. The service tech will try a new control panel assembly, or the module(s) that have the related circuitry. Once the defective modules are replaced, the tech will leave in the new modules.
When under warranty and these sets are exchanged under warranty, they give you back a set that was serviced from someone else. That is the drawback with having the set serviced under warranty.
Jerry G.
Posted on Feb 10, 2009
    Master:
  • 848 Answers
Hi
check the main fuse that should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as soon as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply.......
Check horizontal output transistor.............
you have warranty go with it .......you can get it fixed ....
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
TV doesnt Come On
HI,
Can you please give the make and the model no.
Jun 07, 2008 | Televison & Video
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My polaroid TV will turn on but there is no picture or sound
blown caps in the power supply a 470m at 16 volt cap it will be puffed up
Sep 18, 2009 | Polaroid FLM-323B Television
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Feb 05, 2009 | RCA Televison & Video
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
913 people viewed this question
Top Westinghouse Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
