Question about Olevia LT37HVS 37 in. LCD HDTV
Buttons on the TV Display quit working
All of the sudden none of the buttons on the display respond including:
source, vol+,vol-, channel^, channel down, menu, power.
Luckily the remote presently can control these. Hopefully it doesn't quit.
My extended warranty from Target expired in December.
Is there a reset or anthything that can be done?
    Genius:
  • Olevia Master
  • 1,673 Answers
The control circuit board assembly most likely has to be replaced, or the circuit board that has the control circuits has to be replaced.
The only basic thing you can do is open the set and look for any loose connections. Beyond that, there is nothing you can do yourself.
Many times when cleaning the screen people tend to use too much liquid cleaner and they get drops of liquid in to the set through the lip of the bezel. This will usually cause damage to any electronic areas that the liquid comes in to contact with.
Take care, these sets can be fairly expensive to service.
Jerry G.
Posted on Feb 10, 2009
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
Ilo tv in spanish need english
To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Aug 22, 2011 | iLO IWT3206 TV
We have no remote for tv, the child lock has been set manually and it has disabled the volume and channel control
On the side of your tv press the MENU Button to display TV Channel. Press the P+/P- buttons to select the CHILD LOCK OPTION. Press the VOL+/VOL- buttons to enable or disable the function. ON means it is locked OFF means function key is active.
COPY & PASTE THIS LINK INTO A NEW BROWSER AND CLICK SAVE. This should bring up your user manual for this specific TV. Good luck.
http://www.google.com/url?sa=t&source=web&cd=4&ved=0CDsQFjAD&url=http%3A%2F%2F86.89.130.62%2Fcache%2Fdocument.php%3Fdata%3D79643CB3-508D-5B6A-8586-160F02C5E75A%26file%3DGTVL20W7HD.pdf%26archive%3Ddoc00010&rct=j&q=goodmans%20gtvl20w7hd%20child%20lock&ei=FvN3TfKRCITXrAHFqoXQCQ&usg=AFQjCNEQJIgfu81RtZzD_Qum0XeSXcrlgA&sig2=RTLdIG-mbWg-0URhTIN97Q
Mar 09, 2011 | Televison & Video
How do i get regular tv channels no cable or direct tv. I have a 32' magnavox model #32MF338B/F7
Hello
I'm not sure about the model number of your TV, as here it is marked as both "27MS343S and 32MF338B/F7". Anyway I gies this solution as for the first denoted.
Insert antena to the antena socket at the back side of your TV marked as 75Ohms antena input.
[1] Press "Menu" button on the remote control handset to display menu on screen.
[2] Press "Vol+ or Vol--" button repetedly to hilight "TUN" [Tuner].
[3] Press "Ch+ or Ch--" button to hilight 'AUTOPROGRAM"
[4] Press "Vol+" to programming tv channels.
Tv will tune and store channels transmitted channels at that time, through entire bands, and will display the first channel receved after tuning process completed. It may take some minutes. You have to wait it to complete. After displaying the first channel, you can select your favourite channel Using CH+ or CH--" buttons. Ok.
Nov 03, 2010 | Philips Magnavox 27MS343S 27" TV
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
LOCK CODE PLEASE ON 29"TRUSLIM
try zoom and then vol - and disable program lock from the menu.
Jan 19, 2009 | Nolo Dealing with Problem Employees: A L...
Olevia LT37HVS 37 in. LCD HDTV Logo
50 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
