Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Pilot goes off every two to three weeks
My steem boiler goes off two to three weeks i chang thermocouppling every time it worjs again three four weeks and same thing happen again
is this is a gass valve problam that kill my thermocoupling
pls if an body konw about this let me solve my problam
    President:
  • 1,902 Answers
Check voltage at the gas valve and at the thermocoupling. If you are reading more then 24 volts at the gas valve then replace it, or less then replace it also
Posted on Feb 10, 2009
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
Cointra godesia water heater... works perfectly but only for 5 mins then pilot goes out... u can relight straight away and it works for 5 mins again .. this boiler I have just bought new ... j
In my experience thermocouple either work or they do not.when a water heater runs for a length of time before the interupter cuts the pilot or on some modules safety cut out sensor also known as over heat thermostat cuts the gas supply the problem can normally be found in the flue restricting the disposal of waste products of the combustion or the lach of air flow through the appliance
May 19, 2013 | Water Heaters
Flashing ch on greenstar 42cdi boiler
ch calling for heat check ignitor or heating element
Oct 18, 2017 | Water Heaters
Bled radiator and now boiler is losing pressure
if your boiler is a combi re-pressurise locate filling loop and refere to manual
Oct 09, 2009 | Water Heaters
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
Pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Feb 22, 2009 | Water Heaters
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
66 people viewed this question
Top Protech Systems Water Heaters Experts
Paul Carew
Donni Steen
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
