Cars & Trucks Logo
Steve Clark Posted on Feb 14, 2013
2003 jaguar xj8 stuck in park intermittently headlights won't work either
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Feb 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1359
Points
5
Dont think they will be related but when you press the brake pedal with the ignition on can you here a solenoid click under the gear shift? These are common to fail and often don't release the shifter.
5 Related Answers
Anonymous
  • Posted on May 09, 2009
SOURCE: xj8 instrument lights not on when headlights on
Rzahn: I found the solution to our problem. You just need to replace the fuse inside the car. Please check this link to get a detailed description of locating the fuse inside the car.
http://www.jaguarforums.com/forum/showthread.php?t=15700
Anonymous
  • 297 Answers
  • Posted on Aug 11, 2009
SOURCE: I have a jaguar xj8 and the gear got stuck in park.
Most likely the lock out switch at the brake pedal is at fault, because in order to put it in in to any gear you have to step on the brake first ! Their is a switch located which prevents you put it in gear with out stepping on the brake pedal, so check this switch first.
Anonymous
  • 158 Answers
  • Posted on Sep 14, 2009
SOURCE: very noisy squeky fron suspension on jaguar xj8
You might need a lube job or you may need to see if noise is coming from another place such as your engine water pump, brakes, power steering. Look for leaks.
raygin
Raygin
  • 322 Answers
  • Posted on Apr 09, 2010
SOURCE: stuck in park 2003 jaguar s type r sc
There is a plastic pawl that locks the gearbox shift in park. This with wear jams when there is a load on it such as parking on a slope. try pushing the car uphill to ease this load then pull it sharply out of park. Also there is an adjustment on the gearbox end that may need attention/resetting. When parking on a slope - apply parkbrake first and then engage park, this may help. Hope this helps.
Anonymous
  • 610 Answers
  • Posted on Dec 22, 2010
SOURCE: 2004 Jaguar XJ8 Park assist control module. where
PARK AID MUDULE IS IN THE LEFT REAR OF THE TRUNK.
2002 jaguar xj8 when I drive it won't go over 3000rpm
Jaguar wont rev 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > wont rev 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... Wont go beyong 3000 Revs s type 2001, wont go beyond 3000 Revs and it' in limp ... Question about 2002 X-Type ... My jaguar xjr8 year 2000 battery went dead started car went for short drive back ...
Jaguar engine cuts 3000 rpm Questions & Answers - Fixya
www.fixya.com > Forum > Tags > engine cuts 3000 rpm
1998 Jaguar XJ8 won't rev over 3000 rpm ... engine cuts out and shudders at 3000 rpm won't accelerateobd code p0332 2002 jaguar x type 3.0 l P0332 - Knock ... Car is boging out in park and will not go over ... driving, don't worry about it.
Rev Won't go up
www.jaguarforum.com/showthread.php?t=14662
My 2006 XJ8 Jaguar door won't unlock with the key nor the remote.
You will need to have the car towed to a Jaguar dealer to fix it.
My 2004 X-Type suddenly went into 'Limp Home Mode' displayed 'engine fault' and 'gearbox fault' After pulling off the road I shut off the engine and remove the key and wait about...
Having a restoration shop and running several newer Jaguars I have seen similar situations. Intermittent multiple errors such as these can be caused by a low battery (or corroded connections) that "fool the computers". Also had a '99 XJ8 VDP have exactly the same issues over several months. Issue was a manufacturing fault in the sensors on the throttle body that caused the "limp home" mode - usually in stop and go traffic. Jaguar had an inspection and recall on the throttle bodies but that vehicle had gone through 3 different Jaguar dealers for service and none looked at TSB/Recall or performed the necessary checks on the throttle body. Tried cleaning the throttle several times (per Jaguar TSBs) but no change. Had to replace throttle body & problem solved (over 30,000 miles since then). Recommend making sure all air connections to throttle are clean and open and cleaning the throttle area to see if that helps.
On newer Jaguars (and other Al bodied cars) similar problems occur when the "ground" connections to the body become poor (usually through corrosion but sometimes through collisions). Connections may look perfectly normal but have high resistance. Careful when working with the connections - the posts are usually very loosely fastened to the bodies. The engine quit on a 2005 XJ8 VDP when I turned the wipers on (fortunately I was driving slow in a parking lot) because one of the forward bulkhead ground connections was corroded (looked normal but separated from body when removing the wires to clean them).
Also there occur occasional funny intermittent issues with all newer Jags that seem to be untraceable and non-reproducable computer "glitches".Good luck.
Jaguar xj8 2001 just completed timing chain & tensioner replacement. engine cranks won't start, what is the best trouble shooting sequence to use?
DID YOU RECONNECT IGNITION COILS AND THE VARIABLE VALVE TIMING SOLENOIDS.CHECK SPARK PLUGS IF YOU GETTING SPARK AT SPARK PLUGS.MORE LIKELY VALVE TIMING OFF.
2helpful
My jaguar xj8 won't turn over.
do head lights come on? if not you'll need a boost or battery charger make sure it's also in park. try that if not that @ battery is charged turn headlights on turn key if lights dim @ it does'nt start most likely bad starter hope this helps you!!
1helpful
Gear lever stuck in park
This should not be a major problem but get it checked out by a dealer soonest.
9helpful
3answers
I have a jaguar xj8 and the gear got stuck in park ,and I can't put it in reverse or drive. How can I fix this problem
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
