No hot air
I am cold. I am trying to get heat flowing through the house but it isnt working. I go to the thermostat and just put it to on and the system in the attic turns on and blows air. I turn it to heat and dont get any warm air. I know the outside unit isnt turning on and was told it should. I dont remember all these years the outside unit turning on. Of course I try to turn on the a/c and the outside unit still doesnt turn on. What do I need to look for. I have a Tappan 4ton split system if that info helps. Thanks.
  • 6,784 Answers
If im correct, you may have a heat pump system. this unit, when set to heat, will and, should run in unison. if the outside isn't running, its probably a compressor issue. if you don't have a heat pump, you may be experiencing main unit malfunction. some units of this nature have supplementary heating for a back up. it should say this on the indoor thermostat on the wall. set the supplementary dial for now. it should heat until you get this repaired.
Posted on Feb 10, 2009
    President:
  • 1,902 Answers
There could be a couple of problems going on. Your fuse on the heater up in the attic is popped.
Your glow ignition is broken.
Your spark ignitor is bad (if that is what you have)
GAs valve is bad.
Or the vent sensor is bad, meaning that the exhaust fumes are not going anywhere.
Now when you turn on the heater your condensiing unit outside should never turn on unless you are calling for AC. Now if the ac is not coming on there can be more problems.
Disconnect fuse is popped.
Wiring is wrong going to the heating board.
No wires for AC going to the thermostat
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
Mitsubishi l200 2.5 DiD 2007 74000 miles, bubbling in header tank, over heating and pushing water back to the header tank, heater is still blowing hot air!! So dont think its the thermostat, am I more...
There are other things to test before we have the engine spread all over the yard. Cooling fan operation. Yes the thermostat hot air in heater just means hot water. start with a cold engine then start and run at a high idle if heats quickly upper radiator hose hot lower cold good but reverse no flow. remove and test thermostat (not replace) put on stove boil water and watch it open once center piece is moving check with thermometer it should agree with stamp number on thermostat. if good check for slipping fan belt. check for air restrictions on radiator and water flow.
May 04, 2014 | Cars & Trucks
My car over heating and blows cold air had new thermostat housing done but still dont work
Trapped air you have to bleed the air ,open cap when is cold and start car until water goes up to the top put back cap.try two times.
Apr 03, 2013 | Cars & Trucks
No heat
Check to see if this is working.
Jan 13, 2013 | 2004 Ford Freestar
I have a 1997 mercury villager van it started blowing cold air instead of warm out of the vents I replaced the thermostat and still having the same problem the heat only works on and off and now the van...
You have fitted the thremostat in the wrong way around ,the body of the stat goes in towards the engine and thats why you have a hot hose and a cold one the water isnt circulating,when you get it sorted then if still cold heater put some cardboard in front of the radiator to stop the air flow then it work right
Jan 07, 2011 | 1995 Mercury Villager
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
The air condition works great.When it got cold out i tried to put the heat on and it blows out cold air I changed the thermostat and still the same problem.
Check the coolant level, and flow to the heater core. You can check the flow by seeing how hot the heater hoses are. If they are getting flow and coolant level is ok, then you may have an air pocket in the cooling system, these have a bleeder on the t-stat housing to allow you to bleed the air out of the cooling system. If this is ok, then you may have a faulty temp blend door, blend door actuator, or cable.
Oct 17, 2009 | 2002 Mitsubishi Galant
Hater isnt working, it blows air but its cold air.
check your thermostat that could cause you not to get no hot air flow
Oct 09, 2009 | 1998 Buick Century
The heating does not get warm when the car is stationery
try a new thermostat it sound like the problem.
Feb 07, 2009 | 2004 Kia Sedona
Heating & Cooling Logo
170 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
