Question about PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames
Frame will not read thumb drive.
How do I get it to work with external drive?
    Problem Solver:
  • 11 Answers
Go to the store you bought it from or call the customer service on it! it always works like that...... fast and easy!
Posted on Feb 10, 2009
TRANSFERRING PICTURES TO DIGITAL PHOTO FRAME
There are many ways. The easiest being use a external hard drive or thumb drive and simply copy the data to the drive. Plug the drive in the other computer and reverse the process.
Is there something wrong with the laptop?
Dec 26, 2012 | Sungale Gpx 7" Digital Photo Frame
Will my la40c530 read a 2TB hard drive
If your TV got a USB port and can support thumb driver then it'll surely support your external Hard Drive too.
Aug 08, 2012 | Computers & Internet
I want to replace the dvd drive for acer aspire 5100-3357 with another internal dvd drive but I do't know the type or the model #, all I know is that is a super multi double layer and supports DVD +-...
A better not complicated solution is an external drive.
Like the:
LG GP08LU10 Optical MediaSlim External Super-Multi DVD Drive You might not know it from looking at this DVD drive's sleek, slim exterior, but it's loaded with capabilities. LG's external CD- and DVD-burner looks great, and works in four unique formats. Super-multi read-and-write lets you select your style for maximum performance, while the USB connection means there's no need for an AC adapter.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | Acer Aspire 5100-3357 Notebook
My external drive stopped working - it can only read sometimes and sometimes it can not access it at all. I format it and now I can not access it anymore
If it is under warranty, get it replaced otherwise time to buy another one.
Warranty is 1-5 years depending on the model number. Check: http://support.wdc.com/warranty/policy.asp
about 1/3 the way down.
If this was helpful, I'd appreciate 4 thumbs.
Sep 14, 2010 | Western Digital 500GB My Book Pro-External...
External hard drive 3,5" few months it was working properly, and it says usb device not recognized and it doesnot show up. please for solution
Hello sir/ma'am, hi, most likely you have cable problems, check and see if you can find another cable. The cable is the USB data cable, that connects from your PC to the external hard drive.
Please also check if your USB port is working fine, just simply plug in a thumb drive to confirm.
If its not the cable, its the external hard drive. Usually, the red light appears or the device is reading the drive continuously with no action. let me know your progress.
Aug 13, 2010 | Verbatim VER95327 USB Hard Drive
Uploading photos
Both the thumb drive and the picture frame are USB slave devices, not USB masters. They both need to be connected to a USB master in order to transfer files.
Do you have a standard USB cable from some other device, any other device? If so, that should fit into the picture frame. If not, you'll have to buy one.
Connect the thumb drive to your computer. Create a folder on the computer and copy your photos to that folder. Then connect the picture frame to the computer and copy the photos from the folder to the frame.
If you have two or more USB ports, you can skip the folder and just copy photos from the thumb drive directly to the frame.
Jun 04, 2010 | Pacific Digital MemoryVue MV-800 Digital...
My external is hooked up to the frame through the usb, but itwill only let me choose internal memory or slideshow folders, it wont let me choose usb when i try to select media sources. how do i get it to...
The external hard drive is diferent from a regular USB stick, so this is probably the case. You could check the manual of the photo frame and the manual of the externa drive, probably you will find some settings that reffer to this.
You could also check that the external drive is plugged in to AC, and turned on, many drives require alternative power source when conected to low power readers like your photo frame.
Apr 07, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
How do i connect an external hard drive to my LG LCD Tv?
The LG's will support an external USB hard drive, but it seems the USB support was intended for thumb drives, so yuo need to do the following to get it working:
  1. the drive must be formatted FAT32 (like thumbdrives)
  2. keep the file names short
  3. keep the directory structure simple and as flat as possible
I have a 60GB laptop drive in a USB 2.0 enclosure drive working really nicely with good transfer rates. It takes it's power from the USB socket and is working fine.
Hope this helps.
Jan 12, 2009 | Dell Dimension 3000 PC Desktop
My two front usb ports cant read usb hard drives
Some external USB drives require external power sources. Typically this is done either with an external power supply that connects to the drive or a second USB cable that connects to the drive and a second usb port on the pc. I have even seen one drive that comes with a Y cable. one end goes to the drive and the 2 usb plugs go to the pc.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
TruTech 7 inch digital photo frame
Setup Menu>Custom Setup>Repeat Mode>All
Jul 22, 2008 | Electronics - Others
PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
Top PANDIGITAL Audio Players & Recorders Experts
Tom Chichester
d3yavu3
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
