Question about Linspire Five-0 for Linux
How to install windows 2000 instead of linspire 5.0.59
What are the steps to install windows 2000 on a linspire pc , any special commands ?
  • 78 Answers
Unless you have all of the drivers for your hardware and win2000, I wouldn't try it. You'll end up with nothing working.
Posted on Feb 10, 2009
Password reset on dell 518
Reset Your Windows Password Using the Command Prompt
1. Boot your computer using your Windows installation disc.
2. Wait for the setup files to load, and select your language. Click Next.
3. Click the Repair your computer link on the Install Windows screen.
4. Select the operating system to repair, and note the drive letter on which the OS is installed (it is probably C: or D:). Click Next.
5. Click Command Prompt at the bottom of the list of recovery tools.
Now you need to overwrite the Sticky Keys executable with the Command Prompt executable. Sticky Keys is an accessibility feature that allows a user to tap the Shift, Ctrl, Alt, or Windows key once to achieve the same effect as holding the key down. Ordinarily, tapping Shift five times activates Sticky Keys--but with this trick, you are going to make tapping Shift five times activate the Windows Command Prompt instead.
The instructions below use drive letter C: as an example. If your operating system is installed on another drive, replace C: with the appropriate drive letter.
1. In the Command Prompt window, type copy c:\windows\system32\sethc.exe c:\ and press Enter.
2. Type copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. At the login screen, tap Shift five times. The Command Prompt will pop up.
4. Type net user username password, replacing username with your username and password with a new password.
5. Exit the Command Prompt, and log in using your new password.
To prevent another user from exploiting the same trick to reset your password, you can restore Sticky Keys as follows:
1. Step through the instructions above to boot the PC using your Windows installation disc, open the recovery tools, and launch the Command Prompt.
2. Type copy /y c:\sethc.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. Pressing Shift five times will now activate Sticky Keys instead of the Command Prompt. Store your Windows installation disc in a secure location.
May 03, 2014 | Dell Inspiron 530 Desktop Computer
Tip
How to Bypass Windows XP Password in Safe Mode?
As a special diagnostic operating mode of Windows, safe mode which starts Windows with a limited set of files and drivers helps you to diagnose and troubleshoot various computer problems. Whenever your computer crashes or a spyware or virus affects your PC, you can enter safe mode to fix these problems. So when you want to <a href="http://www.anypasswordrecovery.com/bypass-windows-xp-password.html" style="font-weight: bold;">bypass Windows XP password</a>.<br /><br />There are 3 safe mode options, here only shows you detailed instructions on <a href="http://www.anypasswordrecovery.com/bypass-windows-xp-password.html" style="font-weight: bold;">how to bypass windows XP password</a> by safe mode with command prompt, which will starts Windows in safe mode with a command prompt window instead of the usual Windows interface. Before proceeding the following steps, please make sure that you never set a password for the built-in administrator account on your Windows XP machine or you can remember password of a Windows account with administrative privileges.<br /><br />Step 1. Turn on your computer.<br /><br />Step 2. Repeatedly tap F8 key as the computer is booting. It will bring up the "Windows Advanced Options Menu" as shown below.<br /><br /><img src="yaoch.png" /><br /><br />Step 3. Use your arrow keys to select "Safe Mode with Command Prompt" and press Enter.<br /><br />Step 4. Windows will load files until you see a logon screen similar screen with all your account user names displayed. Enter password for your administrator account to get in safe mode.<br /><br />Step 5. You'll see Windows command prompt after entering safe mode.<br /><br />Step 6. Enter "net user" on the command prompt, and press Enter. It will list all the user names of your Windows accounts. Here we assume that there is a user name of "Jack" in the list and you want to bypass the "Jack" account password.<br /><br />Step 7. Enter "net user Jack 123456" on command prompt and press Enter. This command line means that you want to reset the lost "Jack" account password to "123456". When it takes effect, you'll be able to logon the Jack account with the new password of "123456".<br /><br /><img src="yaoch_0.png" /><br /><br />Step 8. Now all the operations compete and you can exit safe mode by restarting computer.<br /><br />Please note this method will not work for you if you cannot enter safe mode with an administrator account. Under this circumstance, what should you do next? Well, don't feel impressed. Windows password recovery solutions aren't limited to this. <a href="http://www.anypasswordrecovery.com/" style="font-weight: bold;">Rekeysoft Windows Password Recovery</a> is another good choice. It only takes you 4 steps to bypass Windows XP password in less than 5 minutes.<br /><br />Step 1. Download and install Windows Password Recovery.<br /><br />Step 2. Burn a bootable Windows password reset CD/DVD/USB flash drive.<br /><br />Step 3. Insert the CD/DVD/USB flash drive in the locked computer and set BIOS of the computer to boot from CD/DVD/USB flash drive.<br /><br />Step 4: <a href="http://www.anypasswordrecovery.com/reset-windows-xp-password.html" style="font-weight: bold;">Reset Windows XP password</a> under Win PE with a few clicks.<br /><br />Of course, if you had created a password reset disk after creating a Windows password, you can easily use this disk to change the lost login password to a new one with ease. It will save you from a lot of troubles when forgot login password to your Windows XP computer.
on Apr 19, 2011 | Computers & Internet
Tip
How to Recover Windows 2000 Password
Forgot administrator password on a system running Windows 2000 can be problematic when the administrator to perform maintenance. There is a trick that allows a computer user to reset his password, if you forgot. The process to recover a password in Windows 2003 and XP is different from the process used for Windows NT and Windows 2000.
Step 1. Insert the installation CD of Windows 2000 / DVD into the drive of the computer and then restart the computer.
Step 2. Select the destination directory for the alternative Windows operating system when the program asks you to do. This directory is not the same as the default installation of Windows. This is the computer is a dual-boot system.
Step 3. When the computer restarts, select the alternate Windows installation from the dual-boot menu.
Step 4. Find the logon.scr file. It should be located in the %systemroot%\System32 folder of the Windows folder.
Step 5. Rename logon.scr and move it into the C: folder of the hard drive. You can choose to move it to a different directory. The important thing is to remember where the file gets copied.
Step 6. Find cmd.exe and make a copy of it in the %systemroot%\System32 folder. Move this file to the C: folder of your hard drive.
Step 7. Right-click on the original cmd.exe file and select "Rename." Delete the cmd.exe text and replace it with logon.scr.
Step 8. Restart the computer and start Windows installation. Do not touch the computer until the start of the screensaver. Since the screen saver file, get the default is replaced with the file cmd.exe, then a command prompt instead of the screen saver.
Step 9. At this prompt type: net user administrator <password>
Step 10. Delete logon.scr from the %systemroot%\system32 folder.
Step 11. Issue the following commands from the command prompt:
copy c:\logon.scr c:\windows\%systemroot\system32
copy c:\cmd.exe c:\windows\%systemroot\system 32
Step 12. Restart the computer in the original. From here you can remove the additional installation if desired. If the administrator installation alternatives are on a different drive or partition to reformat the hard disk or partition is the easiest way to achieve this goal.
on Apr 26, 2010 | Computers & Internet
How do I fix boootmger compressed.
  • Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair".
  • If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files.
  • If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands:
    • compact /U C:\bootmgr
    • compact /U C:\ntldr
  • If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands:
    • attrib -c c:\bootmgr
    • attrib -c c:\ntldr
May 11, 2012 | Dell Computers & Internet
It will not reboot the message 'boot manager is compressed' is displayed and will not move past it
Check points for fixing compressed boot-manager:
  • Boot into Windows Recovery Environment (usually the install DVD or Create a Windows Vista/7 Recovery disk on an USB stick) and perform a "Startup Repair".
May 05, 2011 | Advent 4211c Notebook
Command how to install recovery console?
at first restart the pc than inside erd commander cd. than run the pc and collect the data.
Jun 05, 2009 | Microsoft Windows 2000 Professional for PC
UNMOUNTABLE_BOOT_VOLUME
1. Start your computer by using the Windows startup disks, or with the Windows installation disk if your computer can start from the CD drive. 2. When the Welcome to Setup screen appears, press R to select the repair option. 3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console. 4. Type the administrator password when you are prompted to do this.
Note If no administrator password exists, press ENTER. 5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER. 6. At the command prompt, type exit, and then press ENTER to restart your computer.If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command.
Oct 16, 2008 | Computers & Internet
Linspire Five-0 for Linux Logo
67 people viewed this question
Top Linspire Computers & Internet Experts
David Payne
David Payne
Are you a Linspire Computer and Internet Expert? Answer questions, earn points and help others
