SOURCE: How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
SOURCE: Back Left Burner clicks
Hi!
Please use a blower or hair dryer and blow out any moisture on the back burner knob. This happens when moisture enters the knob area. Moisture shorts the connections and thus, its clicking continuosly.
Also, check for the electrical connections.
Please ask for further clarifications.
Please rate this solution.
Thanks
Rylee
SOURCE: this is my 2nd one of JDS9865BDP which was
These micro switches are standard parts and are available from commercial electronics stores - one of which is Active Electronics in Toronto. A second one is Electrosonic.
SOURCE: Jenn Air gas range- burner not fully lit
Can you verify which burner it is that won`t ignite/burn properly ?
I should be able to help, but I just need some clarity. I`ll watch for your reply.
macmarkus :)
SOURCE: Jenn-Air model svd48600. Gas stove top, electric
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
