Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Lamp on the kdf-50we655
I took out the lamp cause the tv went blank yesterday and the lamp light came on.when i looked at the lamp the bulb was in pieces, what caused the light to break up like that..
    Scholar:
  • 150 Answers
Hi, very common to do that, nothing to worry about, video-tek
Posted on Feb 10, 2009
I HAVE REPLACED MY BULB OM MY KDF-50W655 AND MY TV IS WORKING AGAIN, BUT I HAVE TRYED TO RESET THE TIMMER TO THE BULB THRU NMY CONTROL....BUT CAN'T SEEM TO MAKE IT WORK...
I have installed the new lamp and the the led power light comes on green and than turns flashing red. What is the next step in this repair?
Mar 21, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
KDF 50WE655
3 times blink means Lamp Cover is not placed back that was removed while replacing lamp, make sure lamp cover is fixed securely in its position.
Thanks.
Sep 28, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a sony kdf-50we655 and have replaced the bulb,but tv is showing no picture now. there was a picture for about a month then went out
Ok two things, either the bulb went out really fast or you have an issue with the ballast. Take out the lamp and analize it, it may look good but might be bad, also try to nitce if you catch any clicking sounds when you turn on the tv, because if it's clicking the issue is most probably wioth your ballast.
Aug 02, 2009 | Sony KP-53S35 53" Rear Projection...
Overheat issue on kdf-50we655 sony tv
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Jul 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
SONY WEGA KDF-50WE655
Did you replace your lamp with a generic lamp? Many generic lamps do not produce as much light as OEM lamps do. Also, you may have a separate issue causing the picture to appear less clear than before. Check my solutions to other Sony LCD owners who have had problems with their optical blocks( light engines)
michtech
Feb 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony wega kdf-50we655 went off and thier is a buzzing noise
Anything that sounds like electrical crackling will be coming from either the lamp or lamp driver/ballast boards or their interconnections. The lamp should be examined first as this is the most likely cause.
michtech
Feb 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
LAMP
Replace the lamp. In rare cases, the lamp power supply or lamp ballast may also need replacing. But, replace the lamp first, and use an original Sony lamp not a cheap aftermarket replacement. If this helps, please be sure to rate the fix! Thanks!
Oct 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
99 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
