Question about Lenovo ThinkPad T41 Notebook
Media test failure, check cable
When i boot up my laptop the loading screen for "lenovo" comes up where if i wanted i could go into the bios or boot options...as i let it go the next screen comes on where it would normally show things loading up but instead i get
Broadcom UNDI PXE-2.1 v11.0.11
Copyright (C) 2000-2008 Broadcom Corporation
Copyright (C) 1997-2000 Intel Corporation
All rights reserved
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting Broadcom PXE ROM
  • VALENTELOYOL Apr 17, 2009
    SAME PROBLEM
  • hossamjessic May 10, 2009
    All rights reserved
    when i turned on my computer this morning i got this message
  • 408 Answers
Go into the bios and reset everything to its defaults.It sounds like its trying to do a network boot and failing
Posted on Oct 18, 2011
    President:
  • 1,902 Answers
Video card failure replace your video card
Posted on Feb 10, 2009
3 Suggested Answers
  • 162 Answers
SOURCE: Broadcom UNDI PXE-2.1 v11.0.11 Copyright (C)
Hi. I think the problem on this one is its either your Harddrive has already failed or your Optical Drive has a cd inside, so double check your Optical drive if there is a disc inside it. If not this issue is also with the operating system, you can try to restore your system by pressing the One Key recovery(OKR) button found beside the power button which has a logo of an arching arrow, but remember to plugin first the ac adapter on your laptop before pressing the One Key Recovery Button and also do not press the power button to turn on your computer because when you press the OKR button it will automatically turn on your computer and proceed with the recovery process. When it gives you some option you should choose One Key Recovery and then choose System Recovery, then factory default and from there it will guide you to the whole process of recovering your machine. If this doesnt fix the issue you could also try using the Recovery disc to restore your sytem t its original settings just like the OKR. Lastly you can contact the tech support dept. of Lenovo, they are open 24/7 and this the number to contact:
US/Canada: Available 24/7 1-877-4LENOVO (1-877-453-6686)
Australia: Available 24/7 1300-557-073
New Zealand: 9am-9pm Mon-Fri 0800-446-833. Hope this helps
Posted on Jun 03, 2010
elix0411
  • 3530 Answers
change your boot priority. press power button then keep on tapping F1 key until your reached to setup utility. go to boot menu and set your boot priority 1 to your HDD. if compute wasnt able to detect your HDD . then there is a problem wth your HDD, you need to call you manufacturer for HDD replacement if unit is still under warranty
Posted on Apr 04, 2010
Toshiba nb300 windows starter won't boot. PXE-E61 media test failure. check cable.
If your computer is working fine, then disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, that's why the media test failure is displayed. It's usually used to load an OS image from network.
For the most part not a real problem. More of a warning. Some corporate models use PXE to mass image.
If there is a problem (won't boot) then it lost communications to hard drive, and you need to check BIOS for hard drive.
Oct 03, 2012 | Toshiba mini NB305N410WH Netbook
When I turn on my Dell Inspiron 910 mini, it says tht media test failure, check cable. Operating system not found. Can somebody help me? I dnt know what to do
check the Boot order in the BIOS and make sure that is isn't set to Boot from LAN or Network first as the error "PXE *** Media Test Failure" ( where *** refers to the NIC card ID )
does in fact refer to a pc that is trying to Boot from the LAN or Network first.
If your boot order is set to boot from your Hard Drive first then I would suspect a bad Hard Drive.
Reboot your computer.
This is necessary, as entering the BIOS utility requires that you be outside of your normal operating system.
Press the key indicated during the startup messages to enter the BIOS.
This is traditionally either the "Esc / Delete" or of the "F2" key, but it can be anything, so pay attention to the screen as your computer loads up.
Navigate through the BIOS menu screens, using the arrow keys navigate to advanced bios features press enter to which device has been set to boot from.
using the arrow keys load failsafe defaults or load optimized defaults this will change the boot order press escape then press f10 to save to cmos to restart
hope this helps
Oct 02, 2012 | Dell Inspiron Mini 910 Laptop AC Adapter...
The lid of my Lenovo Ideapad Y510 was slammed down, and it doesn't work anymore. Whenever I try and turn it on, it makes weird noises which include beeping, and tells me to "Reboot and Select proper...
I am sorry that the Computer is not booting. Please try accessing the BIOS by pressing the F2 key or Del key. In the BIOS windiow, press F9 to reset the BIOS to its default values. If you have the service manual of the Computer, please remove the back panel of the Notebook and reconnect the Hard Drive cable.
Jun 30, 2010 | Lenovo IdeaPad Y510 - Intel Core 2 Duo...
My laptop isnt working.as soon as u turn it on a black screen comes up and the message display says PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM!! how can i fix it
It goes to a network boot rather than booting straight to the HDD. restart your computer and press f2 immediatley. you are now on the BIOS page. check if your hard drive is detected and if not call Lenovo to have it replaced/repaired. if it is detected, after the PXE error, your computer should boot up just fine.
Jun 05, 2010 | Lenovo 3000 G530 Notebook
Acer 5620-6266 notebook will not boot--Media Test failure
Open BIOS and configure your boot devices priority. First boot device should be the hdd. Also check if the laptops see the hard disk, i think your hard disk have a problem and thats why laptop wants to boot from network.
Jul 18, 2009 | Acer Extensa 5620 Notebook PC
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Toshiba Satellite PC ... Operating System not found
Enter BIOS by hitting F2. Go to Boot tab and change to default boot. I had the same problem and it worked for me.
Mar 03, 2008 | Toshiba Satellite M30 Notebook
Can't start up the laptop as Media test failure
You may have to go back into the bios and see if there is an option to automatically find HDD, or you may have to manually enter them in the Standard Bios Settings. It may be that the old HDD are still in the bios's recognised setup.
Dec 13, 2006 | BenQ Joybook 5100U Notebook
Lenovo ThinkPad T41 Notebook Logo
2,713 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
