Canon MF 4350d Wont install
Brand new Canon MF 4350d wont install on Dell Dimension 4600 operating system is Windows XP.
Canon said we needed to update USB drivers, downloaded drivers, did not work.
Dell tried to help us install to no avail, they said the problem is with Canon. Has anyone else come upon this problem.
  • srkulariya78
    srkulariya78 Jan 24, 2013
    sir canon mf4350printer lift panel to open open toner cover set paper again set toner again problem
Same problem with Dell 4600C. Tried to connect new Canon Imageclass 4350d monochrome printer. First spoke with Canon technical support for 45 minutes (this is after I spent several hours on my own trying to resolve the problem) and after installing, uninstalling, and installing Canon drivers from disc and online from Canon, same problem: "USB device not recognized". Canon said it must be a computer hardware or software problem with my Dell computer. I then called Dell technical support and was on phone for three hours. They had same problem and suggested I do a complete restore using the Windows XP operating disc that came with the computer when I purchased it in 2003. After doing this time consuming measure, same problem. Dell told me that it may simply be that the Dell 4600C computer and the Canon Imageclass 4350d printer may not be compatible. Both Dell and Canon suggested I try to hook up a different computer and see if the drivers will load correctly from the Canon disc so that the computer will communicate with the printer. Will try this tomorrow, but even it the printer then works, this doesn't solve the problem with using my Dell 4600C computer with this printer. If this is the case, too bad Canon doesn't inform the public about this incompatibity issue.
Posted on Sep 21, 2009
  • ptadin Sep 24, 2009
    After unsuccessfully trying to download drivers and connect my new Canon MF 4350d monochrome printer to my Dell 4600C, I took the printer to work, downloaded printer drivers from the disc to Dell Optiplex computer, hooked up printer, and it worked perfectly. As Dell Techinical Support suggested, the Dell 4600C computer is NOT compatible with Canon MF4350d monochrome printer. Wish Canon would have explored this issued first and posted this potential problem on their website before I wasted hours on trying to solve it myself.
  • Danny Levert Jan 30, 2011
    Did you ever resolve the problem with the Canon MF 4350d and Dell XP? I just got the printer and have the exact same problem? HELP!!!!!
Almost the exact same problem. New 4350d Canon printer trying to connect it with Dell 8300 with XP. The computer says it does not recognize. Tried everything - reinstall drivers, download drivers, tried every USB port, swapped cables, spoke with Canon support and finally took the printer back and got a new one (Canon support person decided the USB board must be bad). New machine - same old problem.
Posted on May 13, 2009
    New Friend:
Lift panel set paper again set toner cover
Posted on Jan 24, 2013
  • srkulariya78
    lift panel set paper again set toner cover
Compatible printers for Dimension 4600?
Any printer available will work. If it's compatible with your operating system software, i.e. Windows XP, Vista or Windows 7.
Oct 02, 2013 | Dell Dimension 4600 PC Desktop
Sir, there is an error i.e system error e225 in my canon mf 4350d machine please help me shut out this problem
Sir, there is an error i.e system error e225 in display my canon mf 4350d machine please help me shut out this problem
Apr 11, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
I had to reload my operating system. But i am not sure f the ethernet driver i need for my dell 4600 dimension
HERE is the driver for your Ethernet card directly from dell. This one is for windows XP. go HERE if you have a different Operating System ans select the correct one. After you select your operating system it should be the only download with the description of "driver" on the list under the networking section.
Aug 29, 2010 | Dell Dimension 4600 PC Desktop
Need sound and vedeo driver for dell dimension 4600 motherboard
You can download the Drivers for Windows XP Operating System here:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=DIM_P4_4600&hidos=NAA&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Jun 25, 2010 | Dell Dimension 4600 PC Desktop
How do you delete a failed operating system on dell 4600 using windows xp
Start to reinstall Windows XP -- one of the options will be to "format" (write 'zero' values everywhere) onto the disk-drive. Voila! EVERYTHING will be "gone".
Jun 15, 2010 | Dell Dimension 4600 PC Desktop
My dell dimension 4600 asks me if I want to open in windows xp upon bootup. Windows xp is the only operating system on my computer. I suspect I have to change a setting somewhere but do not know where....
Hi! You can try this step: Right click on my computer->properties->advance tab, click startup and recovery settings->under startup and recovery settings there is a edit box, click edit then you will see a text doc that refers to the operating system installed.
-you need to delete ONLY the second one that is listed there.highlight the second one and then delete it.save the file and then check if this works
-if this works then you dont have to choose 2 operating system again during startup.
May 25, 2010 | Dell Dimension 4600 PC Desktop
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
1,670 people viewed this question
jasbo
jasbo
