AEG L12700ViT Front Load All-in-One Washer / Dryer
Problem for AEG L12700ViT Front Load All-in-One Washer / Dryer
AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
By samo0910 on Feb 10, 2009
My washing machine leaves me with soaking shirts following various attempts to drain the water.
Solution #1
posted on Jun 15, 2009
Not Rated)
trev_finn
Rank: Apprentice
Rating: 0%, 0 votes
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Was this helpful?
Yes
No
Popular Solutions for AEG L12700ViT Front Load
Questions and Unsolved Problems for AEG L12700ViT Front Load
Do you recommend AEG L12700ViT Front Load All-in-One Washer / Dryer?
Answer
Answer
washer fills up cover is up water leaks out of bottom
Answer
The washing machine is working fine but when you set the the dryer on it goes through the motions... (More)
Answer
when shut door to start wash, press start, a clicking noise occurs and error message comes up
Answer
Cant get machine to work, shut door and select wash program, nothing happens, all the lights come on... (More)
Answer
When I try to use the drying function I get an E320 error just bas the drying cyle begins (when the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For AEG L12700ViT Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14910
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
