Question about Technics SL-1200MK2 Turntable
What all can I attach a turntable ground wire to?
I'm working (as a DJ) with a 3-turntable setup, and my basic problem is that the ground wire is too short on my (Technics) turntables. Whichever turntable is furthest away from the mixer, its ground wire cannot reach the mixer.
Is it OK/effective (on a big sound system) to attach the ground to something other than the mixer? Opening up the turntable and replacing the ground with a longer wire is not an option (I don't have time; the gig is this weekend).
  • 565 Answers
Connecting to another piece of equipment besides the mixer introduces the possibility of creating a ground loop, which, of course, is not desirable.
Just make a splice using Stakons (crimper). Just cut off the existing connector and crimp a (red) round crimp to the existing ground wire. Then take a length of same gauge and crimp a round a (red) spade Stakon on the other end. Then take a nut and bolt and connect the 2 round connectors and tape with good black tape (Scotch 33 or similar). That will get you through the Gig.
Posted on Feb 10, 2009
  • Bob
    Bob Feb 10, 2009
    Correction:
    Use a fork crimp instead of the spade crimp.
  • Bob
    Bob Feb 10, 2009
    All parts readily available at the rat shack.
Cannot connect ground wire on SL BD26
Usually, on Technics turntables, the ground wire is attached to a ground lug on the receiver.
Dec 30, 2013 | Technics SL-BD22 Turntable
What will i need to buy to have a full dj setup?
nowadays you can have a full dj setup with a macbook and some dj software, but if you want to go old school you should get: vinyl turntables and a mixer,
Jan 28, 2013 | Audio Players & Recorders
Target light won't turn off
Your wires are crossed. You'll have to switch them out. Make sure when you put the wires back together, that they are covered properly with either electrical tape, or heat shrink tube. If any part of the wire is exposed and it touches the cabinet, it will ground/short out your turntable, and you'll have an even bigger and more expensive issue to fix.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Mar 30, 2009 | Technics SL-1210 Turntable
Where do I attach the ground wire to the turntable?
You need to attach the ground to a special ground "lug" or "screw" on the next item in the chain.
If this is a dj style mixer then there SHOULD be ground pins on it that you can connect to.
The same applies to a hifi amplifier with phono stage, they generally have ground terminals.
If not you can fasten if securely to the metal casing of the amplifier as this is the same thing.
Technically you can connect it to mains earth but it is ill advised to tamper with mains electricity unless properly qualified.
Mar 28, 2009 | Technics Audio Players & Recorders
New RCAS on Technics 1200 Getting a Loud Buzzing Noise
It is not suggested that you remove the ground cable. Performing the mod for the ground by soldering a bridge on the circuit board doesn't really do anything either than remove that buzz/ground hum. You've essentially removed the wire that grounds the turntable cabinet to the earth. The buzz is gone, but now your turntable is no longer grounded properly.
I would suggest replacing the ground cable to it's original state, then attach the Monster cables.
If this does not work, then either there is an issue with the soldering to the board, or the board itself might be damaged. You might want to look at the trace paths to make sure none are lifted, or damaged in any way on the board. Another issue might be faulty tonearm wires or not properly soldered wires.
FYI, monster cables are not good for this purpose. I would suggest the following cables:
MOGAMI RCA CABLES
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Mar 20, 2009 | Technics SL-1200MK2 Turntable
My SA-600 doesn't work... Dj Rolmixxxx
you do have a soundcard between your setup and the computer?
if not, thats the issue, you need a souncard to decode and recode the timecode for vdj - maya 44 is cheap and does the trick.
Jan 04, 2009 | Gemini SA-600 Turntable
I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 01, 2009 | Technics SL-1210 Turntable
Connect turntables(technics SL1210MK5) to a mixer?
None. The cables are already attached to the turntable. They are hard wired to the unit. The red & White cable. Just connect to the PHONO INPUT on your DJ MIXER, and connect the thin ground wire to the GROUND terminal on the mixer. That's it your ready to go.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Dec 17, 2008 | Technics SL-1200MK2 Turntable
Phono Preamp buzz
Don't forget to ground the ground cable from the turntable.
Sep 15, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
1,721 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
