To install the flash tool, follow the steps below:
You can visit my blog with video Tutor lol
http://pcgadgetdeni.blogspot.com/2013/02/flash-tool-for-xperia-devices.html
SOURCE: i want to format my sony ericsson k700i phone.
you could try to do a master reset with in the settings menu on your phone to it original state.
riz
SOURCE: Sony ericson w810i keeps flashing
i was having w810i and went and charged it after removing it it was flashing white please how can i solve this problem.From bernard
SOURCE: blank screen flashing on and off
I wouldn't call it a easy solution, but your phone is "bricked" anyway; you can attempt to re-flash the phone firmware which can be downloaded using the Sony Ericsson PC Suite.
http://www.sonyericsson.com/cws/support/softwaredownloads?lc=en&cc=us
Just run the "Update Service" application with you phone plugged into your computer using the connection cable.
90% chance your firmware is out of date and the application will attempt to flash your phone and return it to factory settings; you may loose contacts not stored on your SIM card.
If all goes well, your phone will be restored; the other alternative is to take it in for repair.
SOURCE: sony ericsson k850i screen is black whyl the
If this was happening and the update was possible (and successful) I'd try opening the phone up and make sure that the screen connector is properly connected, especially if the phone has been dropped or has taken any type of physical shock.
Otherwise, this could possibly be a water damage related issue.
SOURCE: i have locked my friend
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
1. On the computer: Start PC Companion
