Question about Samsung CLP-510 Laser Printer
Paper jam in tray 1
My Samsung CLP 510, has one tray.  I've looked everywhere, but can find no paper jammed anywhere.  I haven't used this printer for a couple of years.  I wasn't thrilled with the quality of prints so I put it aside. I decided to give it another try and I can't get past this mystery paper jam. The black toner is low, but I don't want to get another until I can print anything.
Hi glenpcr,
I had the same problem and solved it.
At my printer it was a problem of the MP-tray (multi purpose tray).
There are two hinges which keep the open MP-tray in a horizontal position. One of this hinges was broken and I just received it.
Just try it.
regards,
Stephan
Posted on Apr 18, 2009
Clp-510 constantly gives paper jam error, although none exists.
Hello and Welcome
If you are facing this error their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it :
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If problem still exist then best option to contact Samsung Printers Service Provider, Your problem will be solved,
I hope this solution will be helpful for you
Anymore help, I am here to help
Thanks
Mar 26, 2011 | Samsung CLP-510 Laser Printer
Samsung clp 510 model, paper keeping jamming please advice
where does the paper jam. in the drum unit or fuser unit. be specific so i can solve your problem
Oct 01, 2010 | Samsung CLP-510 Laser Printer
My paper starts to print but stops half way through and causes a jam???? what part do I need to get??
Might be the same problem that we see on the CLP 310s. Bad exit sensor. Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Jul 12, 2010 | Samsung CLP-510 Laser Printer
Hi, I've had this Samsung color laserjet (CLP-510) for a while now - found no reason to upgrade cause it's a great work horse. Now however from job to job it grabs an extra sheet of paper or two, and then...
It seems more likily that your pickup roller and separation pad has already worn out.
You may want to try pull out your paper tray and remove the pickup roller. Adjust the pickup roller and the paper tray separation pad may help.
next you may want to test with a single sheets of paper to see if the paper jam at the back of the printer near exit. If it does, you will need to replace your fuser too.
you can check the supplier info by going to menu -> system setup -> report -> supplier infor -> print -> yes.
Information below for item that is wear and tear.
1. Fuser - 25K +/-
2. Transfer roller 20K +/-
3. Transfer Belt 25K +/-
4. Pickup roller 20K +/-
5. Image Drum 25K +/-
hope this help :)
SamsuTech
Feb 20, 2010 | Samsung CLP-510 Laser Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
Jamming when Print heavy paper on Samsung 510
printer only handles up to 120gsm,any thicker will jam.
Jul 11, 2009 | Samsung CLP-510 Laser Printer
Paper jammed
how to unlarge a paper jam in the compaq A3000
May 27, 2008 | Samsung CLP-510 Laser Printer
Printer Jam
Its probably stuck wrapped around the fuser.
It WAS glossy Laser paper and NOT glossy Inkjet paper wasn't it ??
Glossy Inkjet paper could cause a proplem like this, as inkjet paper just isnt made to stand the temperature of a fuser (the fuser cover reaches a temp of just under 180 Celcius) and it melts !!!
Dec 12, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
307 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
