Question about Jandy AQUALINK RS TELELINK KIT
Aqualink rs6 program canceled and does not recognize chlorine gen
Chlorine generator stopped working after memory was cleared, filter, cleaner and waterfall still work but chlorine generator does not?
My aqualikrs6 is stuck in spa mode and will notgo into pool mode.
denikenr@comcast.net
Posted on Jul 27, 2009
  • 125 Answers
How do you reset the memory on a aqualink rs6 timer
write down all your auxillaries and if you have acuators because when you reset all is gone go to system set up then clear memory button then reset the button on front of aqualink then reprogram
Jul 29, 2014 | Pool & Spa
How do I cancel a program a program and reset a time?
go into system set up and go to set time reset and go to program then highlight what needs to be changed edit or remove program
May 02, 2014 | Zodiac Jandy AquaLink RS OneTouch RS6 Pool...
Aux 4 is programed, I want to cancel the program in the aqualink RS6
go into system set up go to program and edit or delete program on Aux 4
Jan 26, 2014 | Jandy Pool & Spa
How do I cancel a program and reprogram the Jandy, Aqualink RS6
go to system set up then go to program highlight what you want to change then edit or delete program
Jan 02, 2014 | Jandy Pool & Spa
I cannot figure out in the RS6 menu how to delete a device program. I have two programs for my cleaner and want to delete one. Anyone know?
The best thing you can do is to clear the memory for the system this should be done once in awhile it is like rebooting your computer.
Here are the steps;
1. Press the menu button
2. Now press < button till System Setup is displayed
3. Press enter
4. Press < till "Clear Memory" is displayed
5. Press Enter
6. Press Enter
You will get a message saying " System Memory is being Cleared"
Once it is done the display will go back to scrolling mode
Now reprogram the system as you normally would
You should do this "rebooting" once a year it will make the system run alot better.
Aqualink systems can get a issue called "Ghosting" which is equipment will get programed to run all on it's own. We see it alot in the bigger systems (RS8 and up) for some reason. We are a Jandy warranty center have been for 10 years now.
Hope this helps
Jan 08, 2011 | Jandy AQUALINK RS TELELINK KIT
When the filter pump comes on, the cleaner booster
check the programs or better cancel all the programs and restar from the begining if still after this the spa side switch need to be replace
Sep 11, 2009 | Jandy AquaLink RS2/6 All Button Dual...
Aqualink Chlorine Generator not producing any chlorine
It shounds like that you might have a mustard algae issue. It feeds on chlorine. It is possible that your unit is producing chlorine but the algae is consuming it as fast as it can be made. You will need to do a shock treatment and use an Algae 30. It could be something else, but this is likely. You can google mustard algate treatments and read up on it to see if you have other symptoms.
Jun 04, 2009 | Jandy AQUALINK RS TELELINK KIT
Need to clear a program from my aqualink
Start with the cancel button. It will then prompt you to cancel the desired program. Go through the menu as you would with a program but follow the prompts to cancel. Remember, press cancel to start.
Dec 26, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
613 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
