Question about Linksys WRH54G Wireless Router
All lights are on, what is the problem
I reset the device but still all the lights are steady-on and not blinking.
  • rockthemic May 11, 2010
    are you connecting via ethernet or usb?
    Scholar:
  • 54 Answers
Hmmm...
if all the lights are on even after resetting the box then it seems the hardware has gone bad......before that let me suggest that you can go a hard reset......let the router be turned on and hold down the reset button for about 60 second then after that plug out the power and wait for 1 min even after that all the lights are no then u need to change the router.......
vedhick
Posted on Feb 10, 2009
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Turn signal and Hazzards issue
Turn signal flasher. Replace with a heavy duty one.
Mar 20, 2014 | 2001 Jeep Cherokee
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
HP4550 - 49.00FF service error
Turn off the RAM disk on the printer.
Follow these steps:
Troubleshooting steps
1.
Verify that the formatter light is blinking or steady. If the formatter is blinking, it is functioning properly and probably does not need to be replaced. If the formatter light is not blinking, proceed to Step 2.
2.
Turn off the printer and unplug the power cord.
3.
Remove the HP Jetdirect card, third-party device, hard disk, parallel cable, or IFR cable from the formatter if one is installed.
4.
If the error continues with accessories removed from the formatter, perform a cold reset on the printer. Ensure the HP Jetdirect card is not in the printer during a cold reset or the card settings will be changed back to default settings. To perform a cold reset, do the following:
1.
Turn on the printer.
2.
Watch the control panel.
3.
When the memory starts counting, press and hold the green (Select ) button.
4.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE .
6.
Press (Down Arrow ) button once. The control panel will display COLD RESET
7.
Press (Select ). The printer will perform a cold reset and then continue its power-on sequence.
5.
If the printer comes up to ready, print a Configuration page. If a 49 error occurs from printing internal pages, continue on to the next step.
6.
Turn the printer off and unplug the power cord.
7.
Remove the eight screws around the formatter.
8.
Remove the formatter. See Figure 1.
9.
Reseat the firmware and memory modules on the formatter. Check for any DIMMs that are non-HP and remove them. Non-HP DIMMs are not supported by HP and may cause this error. Replace with HP DIMMs, if necessary.
10.
Reseat the daughter (interconnect) board. The daughter board is connected to the formatter behind EIO slot #1. To release the daughter board, push in the black retaining tab underneath the formatter then lift up the one side of the daughter board.
11.
Reseat the daughter board.
12.
Install the formatter.
13.
Turn the printer on again.
14.
If it comes up to READY , print a configuration page. If a 49 error does not appear from printing internal pages, or at power up, continue to the next step.
15
Install the HP Jetdirect card and hard disk before installing the formatter. Verify that each device is properly seated.
16
Test any EIO devices, by turning off the printer, installing each device separately, and printing a Configuration page. Repeat for each EIO device.
17
If the 49 error occurs with any EIO device installed, replace that EIO device.
Oct 05, 2010 | Computers & Internet
Maintence light blinking 7 times, what does that mean?
Hello.
Your Maintnance Light is blinking because your vehicle is nearing its recommended oil change interval.
The Light blinks when you reach 4,500 miles, and will come on, and remain on steady, after 5,000 miles,
If you had your oil changed recently, your light was not reset. Changing the oil does not reset the light. It must be manually reset, via a button on the dash; this procedure is explained in your owner's manual
Dec 01, 2009 | 2003 Toyota 4Runner
Hello There blinking lights on my router and I am not getting a signal. Can you help me?
Hi! you have blinking lights on the router, we need to do the hard reset on the router. how? there is a button on the back of the router you need sharp pointed pen or pin to press it. you need to press it for 30secs after 30 secs while the reset button is press, unplug the power plug at the back of the router and plug in after 2secs while the reset button is press and press and hold it for 30secs.. release it and unplug the power plug for 15secs and plug it back in..this should work, the power light should steady and the other lights like port 1 to 4 if there is a device connected there it should stat solid and the wireless light will blink if there is a wireless device trying to connect to the wireless network. if not..and the device is still under warranty, call linksys tech support for replacement and they are going to replace it for free and if the device is still on 30 days, u can return it to the store were u purchase it..
Aug 16, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRH54G Wireless Router Logo
91 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
