Question about Coleman Powermate Powermate 5000W Generator
Generator will not produce electrical power.It will kick reset button
    Brigadier General:
  • 3,614 Answers
May i know exactly the type of and model of the generator?
Posted on Feb 10, 2009
  • micromaster
    micromaster Feb 10, 2009
    1. Run the generator for at least twenty minutes, to make sure no breakers are tripped.
    2. If you can get to a brush any where on the unit, remove it and put it back without rotating it, and try the unit again with a low wattage load connected, make sure the engine is up to speed, look for the simple overlooked things first,
    • If you have no gen experience, you need a service man, there is nothing we can do writing back and forth to fix it without tons of measurements, try the idea of putting a low wattage and correct voltage light bulb on the output and see if it starts to get brighter.
    • If so it may self excite, there are diodes to check, regulator, either electronic or rotating, brushes, windings, has to be check.
Generator was running fine and then the electrical output quit while the engine was running.
Sounds like you did overload the capacity of the generator. What has happened is that the generator was happily running away producing the electricity required for approximately an hour and then an appliance such as an air conditioner, furnace, refrigerator, water heater, or similar large amperage draw fixture decided it was time to kick on for its cycle, or perhaps two or three of them kicked on at the same time, thereby raising the amperage requirement beyond the capability of the generator. All heavy duty appliances run at a given amperage but when they kick on for a cycle they draw almost 50 percent or more amps. Generators rated at 6000 amps or less will not power an entire home or business. When using this size of generator, disable some of your electrical items in the home by unplugging or switching off, and only connect the most important items needed for emergency use. A 3500 watt generator will only run a few lights and a television, plus only one appliance. This means that you could plug in the refrigerator and run it until it has gotten cold enough, then unplug it & connect the furnace or air conditioner or water heater so that they can do there job. Eventually you will be able to rotate through each appliance in turn, and hope the power will return soon. Your generator will likely have blown a capacitor, resistor or some similar repairable item. Some good quality generators will have an overload breaker installed, that trips before doing any damage and all that is needed is to find it and reset it, in order to continue using the generator.
Dec 05, 2013 | Campbell Hausfeld GN5060 - 5000 Watt...
Tip
Generator runs great but produces no power
On Thursday last week I had 220 amp outlet being used and a 110 amp outlet being and overloaded the generator. It turned out to be the reset breakers failed to trip and blew the capacitor. The reset breakers I would suggest replacement after 7 years very easy to do on a 5500 Valsi generator 2010 model still running and now producing electric. And of course use only regular gas non Ethanol.
on Aug 19, 2015 | Electrical Supplies
Gnerator not producing ac power
I recently had a similar problem during "Sandy". I forgot to turn off the hot tub before starting the generator and the house lightswhere barely lit, dim, and flickering under the load. I quickly shut itoff andthe hot tub, but not before frying half of my generator. It will only produce 110now, not the 220 usual adn I need to get it fixed. I imaging you may be experienceing the same thing if you can't reset it. My generator has two reset buttons right next to the outlets on the unit itself.
Nov 03, 2012 | Electrical Supplies
GENERATOR WILL RUN BUT DON'T PRODUCE ELECTRIC
Hi and welcome to FixYa, I am Kelly.
Without a model number... I am guessing about what type / brand and MODEL of generator you have. I have to assume it is a Coleman Power mate.
Try flashing the field. Do this.. take and electric drill and plug into the outlets of the generator. Turn on the output power GENERATOR ON. Squeeze the drill trigger and rotate the chuck as fast as you can. This will induce voltage into the stator and they usually will start producing power. When it does produce power it will try to yank the drill chuck head out of your hand so keep that in mind.
If the above does not work...
Remove the small cover from the center of the endbell. It covers the end of the rotor shaft and has 2 brushes under the cover.
INSPECT the brushes visually (do not remove them yet)
(Generator OFF!)
Use a meter to read resistance by probing the electrical contacts of the brushes. You MUST read LOW resistance. This is the rotor winding.
No resistance or high resistance
Remove the brushes inspect for damage. Try to probe the slip rings of the rotor. (You might have to make a 14/2 Romex electiral wire extension to get some solid copper wires to touch the rotor slip rings) Again you must read LOW reistance.
If you have low resistance and the brushes are good.....
Reinstall the brushes. (TEST for AC) Start generator
STILL NO OUTPUT?!!!!
Use a meter on DC to read AVR voltage output to the brushes by probing the brush terminals. You should read 3 - 7 VDC. No voltage.... hmmmm Possibly an AVR problem but...
Try this.
Rig up a 9 Volt battery that you TAPE the wires to the battery terminals and the case of the battery
Just loosely connect the 2 wires to the brushes. Wrap the battery with a rag it might explode if you don't remove it fast enough. Your going to yank this off as soon as it produces power QUICKLY.
Plug in a light or a small fan so you can see that power is being produced. Let it run a few minutes before shutting it down.
To do anything else I need to know your generator model number to do winding and voltage regulator checks.
Thanks for choosing FixYa,
Kelly
Aug 30, 2011 | Coleman Electrical Supplies
I have a 5500Watt BSI550 generator that lost AC while in use. It's only putting out about 5VAC. I Tried several other capacitors and even without a cap it's still putting out about 5VAC right at the...
No electrical
output
1. Faulty receptacle. 1. Have Service Center
replace.
2. Circuit breaker kicked out. 2. Depress and reset.
3. Defective capacitor. 3. Have Service Center
replace capacitor.
4. Faulty power cord. 4. Repair or replace cord.
5. GFCI switch breaker kicked
out (if equipped)
5. Depress and reset
Apr 28, 2011 | Porter Cable 5,500 Watt Portable Generator...
My coleman powermate 6250 generator just stopped producing electricity. It was running all day. Motor still runs just no juice.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Mar 02, 2010 | Coleman Powermate Premium Plus 6250W...
Generator runs great but doesn't produce any power
There is a electronic module that senses load current that pulls the throttle up for high RPM. Fine the module and look it over, you may need to replace it.
Jun 23, 2009 | Coleman Powermate Premium Plus 6250W...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Generator will not produce electric power
Check the air cleaner to make sure that it isn't clogged with oil. If you find any significant amount of oil you may also need to clean the carb. Also check the spark plugs for fouling. Once you're convinced that the engine has no service related issues, check the governed throttle setting. To do this find the spring that pulls on the governor arm and look for either a tab to bend up or a threaded rod to tighten at the end of the spring not connected to the governor arm.
Regards,
Carl
Feb 10, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Rivera
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
