SOURCE: Just replaced broken pull 3-speed switch. Fan now
I ran into this when replacing the 3 spd switch. The replacement switch has a pair of connections at each position; you would assume the two connections are electrically tied together, they are not. The switch assembly actually has two seperate 4-position rotary switches. If your "L" wire is on the 'inner' connection, then your motor speed wires will have to be as well.
SOURCE: 3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
