Question about Scotsman Cooled Modular Contour Cuber Remote Condensed 425lbs
Unit turns off on ref code
Unit makes several times then turns off on refg code reset then does the same thing
  • flucum1 Feb 10, 2009
    scotsman cme656 rs unit has 2 lights one water code one refridgeration after the machine runs thru 8-10 cycles it shuts down on yhe refridgeration code but the freon is correct and the unit is only 4 mo. old
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    BAd timer, what is the make of this system and and can point you in the direction of the problem
    President:
  • 1,902 Answers
Is it making the proper size cubes?
Posted on Feb 10, 2009
What errors does Intex E96 code cover
make sure pump is primed
Sep 14, 2014 | Pool & Spa
Subzero 695 Ice/Water dispenser problem.
maybe ice formed around chute from leaky air seal??? warm area with hair dryer blowing hot air up into chute for 10 minutes. check for water and wipe all off. unplug refg and plug in after 3 minutes to reset electronics
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Sub-Zero 695/O Side by Side Refrigerator
F$P refr model E522 keeps beeping as if the door is still open intermittently
pls check your users manual may be your ref. has a door sensor that if is open intermitently it is beep but theres no problem with the operation with regards to cooling thus means your ref is normal. try to reset by unplug your unit and after several minutes plug yuor unit then observe.
Feb 17, 2011 | Fisher and Paykel Refrigerators
We want to change the the old code number and enter a new number. I would like to know how we can do this.
if you look on top of the unit, you should see a small screw - remove that screw. now you will need a small stiff wire, punch in your original code and then take the wire and push down through the hole ( this will reset wheel pack ) -- now punch in your new code and then rotate door handle to the right. now try your new code several times to make sure it took and that should be it.
now I have seen some of these units that do not have the access hole in the top -- if this is the case then you will need to access the reset button from the back of the unit -- remove the lock from the door, now look at the back plate -- you should see 6 small philip head screws -- remove those screws and remove the plate. now look at the middle of the unit - you should see a long rectangular box unit ( this is the combo pack ), now on the top of the combo pack you will see a small lever, now from the front of the unit - press in your old code, turn the unit around and with a flat blade screw driver push down that little lever,, now push in your new code,, rotate the door handle to the right ,, test your new code several times and re-install unit,, and you are done.
c...
Jan 24, 2011 | Simplex Kaba 6200 Push Button
My Olympus Camedia C-750 will not turn on. When I start it, the screen looks normal but then goes blank. it stays lighted and then beeps several times then makes a noise like a picture has been taken,...
If those batteries are definitely good then the electronics of unit have gone haywire. Contact Olympus to see if there is some sort of hidden code to reset electronics to factory defaults.
Sep 05, 2017 | Olympus Camedia C-750 Ultra Zoom Digital...
Volvo v40 p ref radio says code where do i get
Radio code is specific for each and every car. It is specific like anti theft code.
So you can get it by providing your VIN# and registration details in authorised dealership.Nobody else can provide you. If anybody can provide you that , then there is no meaning of security for your car..
Jun 13, 2010 | 2000 Volvo V40
Disposal hums but doesn't rotate. I would like to know where the reset button is so I can see if that is the problem. I've tried turning the inside mechanism but it won't rotate...
There are several things you can check. First make sure the unit is off and check for debris stuck inside the unit. On the bottom of your Disposal is a slot for an allen wrench also most have a reset button here also. First take the allen wrench and turn the unit around several time manually before you do anything else. Now run some water down the unit and see if it will turn on. If it doe not try the allen wrench one more time and do the same as above. Now try the reset button. If this works great because the next step requires you to take the unit off. Let me know if this works before we go to the next step. Hope this helps.
JimmyC
Oct 08, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
What is the master reset code for the denon avr 1508?
Turn the unit off by main switch (not a standby button).
Press and hold "Speakers-A" and "Speakers-B" buttons and turn on main switch.
Display blinks.
Release the buttons after 3 seconds.
Receiver is reseted.
Jul 20, 2009 | Denon AVR-1508 Receiver
Code h4-01 on sharp ar407 had stuck sheet of paper cleared and still have the code.
H4 means the copier (fuser) does not reach a specified temperature within a given time frame.
This means one or more of several things. A bad or dirty thermistor or thermostat (most likely) or a bad heater lamp or a bad control board or AC supply.
The first thing to do is reset the error and see if it comes back. To do this enter service mode by pressing the following keys one after the other (make sure you are in copy mode) "P" "interupt" "C" "interupt" then enter 14 and "start" then enter "1" "start" and accept the reset. Restart the copier. (DONT play around with any other codes)
If problem persists then you may need to remove the fuser unit and take it apart in order to inspect/clean the thermistors and maybe reset/replace the thermostat.
Mar 27, 2009 | Sharp AR-407 Copier
Xerox XD100
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Nov 02, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Scotsman Cooled Modular Contour Cuber Remote Condensed 425lbs Logo
132 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
