Question about JVC AL A158BK Turntable
How do you reinstall drive belt for JVC AL A155 model turntable?
I need a diagram to perform the above task please
  • 104 Answers
Http://www.archive.org/details/Turntable_Belt_Installation
archive.org above has a video about how to do it. The general method shown applies to just about any turntable including your JVC
Posted on Feb 10, 2009
Why does the turntable on my JVC AL-E300 stop when the arm drops on to the record. Just changed belt.
Does it restart if you manually lift the arm up?
If it does then you might have not put the belt on right. Another reason is that the problem was not the belt, but a motor showing the signs that it wasn't coping when under load. This could be caused by grease or muck inside the motor or in the drive functions. However the motor could be faulty.
May 16, 2015 | JVC Audio Players & Recorders
Clarinette 107 stereo cassette 8 track and record player. stereo works, but record player will not work. how do i find the problem?
I'm assuming you have a belt driven platter. Lift up the rubber mat, turn the platter it to where the motor spindle is, and see if the belt is still on. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 12, 2013 | JVC AL A158BK Turntable
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Jvc al a155 spins to fast. can i adjust that?
make sure first of all that your belt is riding on the drive pulley like it is supposed to do if this is good under your plate that u take off too replace the belt r two screws they will fine tune adjust your record speed on is for 33 other is for 45 should b marked which is which
Sep 19, 2013 | Audio Players & Recorders
Need to replace the belt on my JVC AL-A95 turntable
To replacea turntable drive belt.Copyright.. Styluscity.com, JohnHarrison. Nov 2011Before starting any work on yourturntable disconnect it from the mains power supply.Remove the stylus or completeheadshell to prevent any accidental stylus damage.1. Remove the rubber platter mat toexpose the platter.
2. Put your thumb and forefinger through the two round holes either side of thecentre spindle and lift the platter off. You may need to give the centrespindle a light tap (whilst applying upward pressure) with a screwdriver handleor some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter and motor pulleys with an alcoholswab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure it is sitting flatwithout any twists.
5. Flip platter over the right way up. Acorrect fitting belt will stay put and an over belt will fall off.
6. You will see 1 or 2 largerectangle or square shaped cut outs in the platter near to the outer edge. Throughone pinch up the belt and slip a finger or belt hook between the platter pulleyand the belt gripping the belt ready to fit over the motor pulley.
7. Align the centre hole of the platter with the spindle and place platter backinto position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotationto ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correctoperation.
MUSIC IS LIFE, LIVE IT LOUD.Styluscity.com cansupply replacement drive belts for all turntables
Oct 08, 2011 | JVC AL A158BK Turntable
Jvc turntable
hi, please check first your fuse inside your turntable, replace it if possible
Apr 04, 2009 | JVC AL A158BK Turntable
JVC Turntable model AL A1 BKX , need to know how to adjust speed
I have just fixed this problem on my Aiwa PX3800 with improvisation.
The platter was rotating too slowly, I didn't know how much too slow only that the records sounded wrong.
I imagined the belt, motor and platter as a bicycle gear and so simply increased the gear... I achieved this by winding a thin strip of a electrical insulation tape around the motor head to increase it's radius (like changing up to a larger front cog on a bicycle gear).
I could then time the rotations and remove a layer or two of the tape accordingly until I have achieved a perfect 45rpm. 33 is still way out but I only listen to 45s!
Be sure to trim excess tape from the motor head with a craft knife/scalpel or it'll stick to the platter.
Poor man fix up.
Dec 17, 2008 | JVC AL A158BK Turntable
JVC AL A158BK Turntable Logo
1,742 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
