Question about Toshiba Satellite M35X-S149 Notebook
Laptop will not completely start
When the laptop is turned on, I hear a humming noise for a short period, then nothing. The screen is blank. Once in a while If I keep doing that, I can see the start screen for an instant.
  • Bill Speer
    Bill Speer May 11, 2010
    Does the power stay on at all times? Have you tried plugging in another monitor to the back? You can check to see if it's the monitor by booting up in a completely dark environment. Sometimes the backlighting is just about shot but you will see (barely) the screen. Let me know and we'll take it further.
Look there is ground cable underLaptop will not completely start - 8c3a205.jpg that plastic cover,, is easy to find,,,,is a cable with a metal ring, take the plastic cover out hold the cable by its metal ring turn the computer on keep holding the cable during the whole booting process and the resolved you problem,, for some reason is not grounding like it should, you have to find a way to ground it to resolve the problem
Posted on Mar 02, 2009
  • 66 Answers
Check your memory remove the memory from the memory slot then clean the memory PIN with the rubber erase then installed it back. turn back your laptop if problem persist try to use another memory. you may also check the the display by using separate monitor.
Posted on Feb 10, 2009
My toshiba at200 table 10.1 wont turn on
1. When you press the power button to turn it on, do you see any thing on screen, like the toshiba boot up screen or something like that. Or is it completely blank (black color) always.
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). This is important to confirm.
3. Also, when you press power button, do you see the LED lights on laptop blinking or solid green (which ones are in blinking/solid) and do hear any sound ? Or do you feel that your laptop doesnt even try to boot.
4. Can you hear any Beeps when you try to turn on the computer. If yes, what is the sequence of those beeps.
Continued......
If you answers are -
1.
blank
2.
no image
3.
only the satellite light is blue, the powercord is blue and the battery is blue
4.
no noise
Please do the following carefully and let me know result :
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the finger and wait one more minute.
6. Now plug in the power cable (dont insert battery yet) and press ON button.
7. Did your screen start working now ? (do you see windows loading)
Jan 04, 2015 | Video Game Consoles & Games
2Days before my laptop was Frozen. I tried all possibilities to shut down neatly but nothing functioned. I swtiched power later. SInce then when ever I start its showing a Black-Blank screen. Things to...
sir
once i found same problem in my client laptop... change a small part wich is beside the power jack ...part name is crystal... u have to open laptop... u can replce from any other dell laptop... im sure it will work .. if not just heat vga card little bit...if again same then u need to replace bios..
1st try to change crystal 2nd vga 3rd bios Thanks
Oct 15, 2010 | Dell Inspiron 1501 Notebook
Do not start up, black screen
I'll asume something for this one it might help. Make sure your laptop is completely turned off [No fans turn, screen black, no hard drive light]. When you then press the power button, immediately keep pressing the F8 button on your keyboard. It should then actually display two options after a while :
*Delete restore/resume point and start windows
*Resume restore/resume point
Select 'Delete restore point' and the unit should boot up fine again.
I had a unit that was basically turbo-booting into windows, but the restore point was corrupt and it always seemed it had a 'blank screen' problem.
You can also try to access the BIOS by pressing F2 as soon as the unit starts up to see if you can actually access the BIOS.
If that all doesn't help I suggest reseating RAM.
May 23, 2010 | Acer Aspire 9800 Notebook
Get's to the starting up screen then goes blank...
you will need to reload windows and it should be fine
Aug 02, 2009 | Dell Inspiron 1100 Notebook
Lwhen laptop is turned on it only gives a blank screen.
I am having the same problem with my Compaq. I boot up and I can hear it whirrling and doing its business but the image is blank. It lights up but no image.
Mar 01, 2009 | Computers & Internet
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
No picture on the Screen!
open your PC.. when your PC do nothing, press fn+f4
Dec 30, 2007 | Toshiba Satellite A60 Notebook
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Toshiba Satellite M35X-S149 Notebook Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
