Question about Frigidaire GLTF1670A Front Load Washer
Shock absorber is brocken - Frigidaire GLTF1670A Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello Ronald Kankelfitz - Consult a professional to move forward accurately. Usually repair or installing information is not release to a consumer and it is very rare to find enough information to do it yourself. In most cases this information can be found on the internet; however it is not provided directly from the manufacturer. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area may guide you through this process.
Posted on Feb 15, 2013
SOURCE:
What othernshocks will fit on a 2002 chevy avalanch 2 wheel drive?
These, and they must be for right model
2002 Chevrolet Avalanche 1500 Shock Absorber
  • 02 2002 Chevrolet Avalanche 1500 Shock Absorber ... www.partsgeek.com/catalog/2002/chevrolet/avalanche_1500/suspension/...
    • 4.8/5
    • 52 REVIEWS
    Buy a 2002 Chevrolet Avalanche 1500 Shock Absorber at discount prices. Choose top quality brands AC Delco, Arnott, Bilstein, Fox Shox, KYB, Monroe, OSC Automotive ...
  • 02 2002 Chevrolet Avalanche 2500 Shock Absorber ... www.partsgeek.com/.../2002/chevrolet/avalanche.../shock_absorber.html
    • 5/5
    • 45 REVIEWS
    Buy a 2002 Chevrolet Avalanche 2500 Shock Absorber at discount prices. ... Comes in three forms of Monotube Shock Absorbers, ... • 2002 Chevrolet Avalanche 2500: ...
  • Related searches for 2002 chevy avalanche shock absorbers
  • 2002 Chevy Avalanche Performance Shocks & Struts - CARiD www.carid.com > ... > Performance Shocks & Struts > Chevy > Avalanche Chevy Avalanche 2002, 4600 Series Standard 46mm Monotube Shock Absorber for Stock Height Vehicles by Bilstein®, 1 per Pack. Finish: Yellow Paint.
  • 2002 Chevrolet Avalanche 2500 Shock Absorber and Strut ... www.autopartswarehouse.com > ... > Shock Absorber and Strut Assembly We have the Largest Selection of Shock Absorber and Strut Assembly for your 2002 Chevrolet Avalanche 2500. Get yours at Wholesale Prices here at AutoPartsWarehouse!
  • 2002 Chevrolet Avalanche 1500 Shock Absorber and Strut ... www.autopartswarehouse.com > ... > Shock Absorber and Strut Assembly We have the Largest Selection of Shock Absorber and Strut ... Shock Absorber and Strut Assembly 2002. Shock Absorber and Strut Assembly for 2002 Chevrolet Avalanche ...
  • 2002 Chevy Avalanche Performance Suspension ' Shocks ... www.carid.com > ... > Suspension Systems > Chevy > Avalanche Bilstein 4600 Series Shock Absorbers and Struts are designed ... Chevy Avalanche 2002, ES Series Shock Absorber by ... 2002 Chevy Avalanche Performance Suspension ...
  • 2002 Chevrolet Avalanche 1500 Shocks & Struts - JCWhitney www.jcwhitney.com > Suspension & Chassis Looking for Shocks & Struts for your 2002 Chevrolet Avalanche 1500? ... 2002 Chevrolet Avalanche 1500 Shocks & Struts ... MONOMAX SHOCK ABSORBERS ...
  • 2002 avalanche shocks ' eBay www.ebay.com > Search > 2002 avalanche shocks Find great deals on eBay for 2002 avalanche shocks 2002 ... Ultima Strut Shock Absorber Full Set Chevy Surburban ... KYB Gas-A-Just Shock Absorbers (Fits: 2002 ...
  • Chevy Avalanche Struts - Best Shock Absorbers & Coilover ... www.autoanything.com/suspension-systems/Chevy/Avalanche/... ... Reviewed for a 2002 Chevy Avalanche -4/26/2016 10:06 PM. After researching various brands of shock, ... Chevy Avalanche Shocks & Struts are Available for ...
  • Jun 10, 2016 | Cars & Trucks
    How to replace rear shocks
    Removal & Installation
    1. Raise and safely support the vehicle.
    2. Support the rear axle and slightly lower the vehicle enough to lessen tension on the shock absorber.
    3. Remove the lower shock absorber retaining nut and washer.
    4. Disconnect the lower end of the shock absorber from the mounting stud.
    5. Remove the shock absorber upper end retaining nut and washer.
    6. Remove the shock absorber from the vehicle.
    To install:
    1. Install the shock absorber onto the upper and lower mounting studs of the vehicle.
    2. Install the washers and retaining nuts. Tighten the upper and lower retaining nuts to 22-30 ft. lbs. (30-41 Nm) on 2001-02 models or 22 ft. lbs. (30 Nm) for the upper bolts and 47 ft. lbs. (64 Nm) on the lower bolts.
    3. Lower the vehicle.
    Jul 07, 2014 | 2004 Nissan Quest
    Pulsar 150 DTSi rear shock absorber gas pressure is low. How to fill the gas into shock absorber and how much pressure of gas to be fill into it?........ and normal AIR can fill into shock absorber...
    The new Pulsar 150 has RSA with Coil Springs and Suspension Fluid. If the Springs are fine, then get the shocks filled with equal amounts of Fluid at major Service Centers (Few workshops have it).
    Else, if the Springs are weak, they can be adjusted by Local Shock Absorber Repairers (Dealers do not suggest it and do not have any mecanism to do it).
    If neither of the above works, you have to finally change to a new Set of Rear Shock Absorbers...
    Nov 14, 2013 | 2005 Bajaj Pulsar 150
    I need to remove the entire passenger side rear suspension. Does it go through the trunk or the back seat? If so how do you remove the back seat?
    REMOVAL & INSTALLATION 1983-86 Models
    1. On 4-door sedan, remove the package tray and vent duct.
    2. On hatchback, remove the speaker grilles.
    3. Disconnect the brake line from the wheel cylinder. CAUTION
      Brake fluid contains polyglycol ethers and polyglycols. Avoid contact with the eyes and wash your hands thoroughly after handling brake fluid. If you do get brake fluid in your eyes, flush your eyes with clean, running water for 15 minutes. If eye irritation persists, or if you have taken brake fluid internally, IMMEDIATELY seek medical assistance.
    4. Remove the brake line from the brake hose.
    5. Disconnect the brake hose from its bracket on the shock absorber.
    6. Loosen, but do not remove, the nut holding the suspension support to the shock absorber.
    7. Unbolt the shock absorber from the rear arm.
    8. Unbolt and extract the shock absorber from the body. To install:
    9. Attach the shock absorber to the body and tighten the 3 nuts to 17 ft. lbs. (25 Nm).
    10. Engage the shock absorber bracket with the carrier and install the hardware. Tighten the nuts to 119 ft. lbs. (162 Nm).
    11. Tighten the center suspension support nut to 36 ft. lbs. (49 Nm). There is a bearing located under the suspension support dust cover. Remove the dust cover and pack the bearing with multi-purpose grease. Once packed, reinstall the dust cover.
    12. The remainder of installation is the reverse of removal. Tighten each component to specifications.
    13. Have the rear wheel alignment checked.
    1987-88 Models
    1. On wagon models, remove the toneau cover holder.
    2. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
    3. Remove the rear wheels.
    4. Using the proper size flare nut wrench, disconnect the backing plate hardware.
    5. With a flare nut and a back-up wrench, disconnect the brake tube from the brake hose and use a small plastic container to collect the brake fluid.
    6. Undo the clip and disconnect the brake hose from the shock absorber. NOTE: Before the axle bolts are removed, the axle carrier must be supported with a jack.
    7. Support the axle carrier with a floor jack and remove the mounting bolts and nut. Disconnect the axle carrier from the shock absorber.
    8. Support the shock absorber firmly by hand and remove the three mounting nuts. Remove the shock absorber from the body. To install:
    9. Position the shock absorber onto the body and support it firmly by hand. Install the three nuts and tighten them to 23 ft. lbs. (31 Nm).
    10. Attach the axle carrier to the shock absorber with the nuts and bolts. Tighten the nuts to 166 ft. lbs. (226 Nm).
    11. The remainder of installation is the reverse of removal. Tighten each component to specifications.
    12. Bleed the brake lines as described in Section 9.
    1989-96 Models
    1. On the 4-door sedan, remove the package tray and vent duct. On 1992-96 models, it will be necessary to remove the rear seat back.
    2. On the hatchback, remove the speaker grilles.
    3. On the wagon models remove the tonnue cover and rear seat back.
    4. Loosen the rear wheel lug nuts, raise the rear of the vehicle and support it safely. Block the front wheels.
    5. Remove the rear wheels.
    6. Disconnect the brake hose and the ABS speed sensor from the shock absorber.
    7. If equipped with ABS, disconnect the Load Sensing Proportioning Valve (LSPV) spring from the lower arm.
    8. Disconnect the stabilizer bar link from the shock absorber.
    9. Support the rear axle and loosen the 2 bolts from the lower end of the shock absorber.
    10. From inside the vehicle, unbolt the upper support. Fig. 1: A rubber cap covers the rear shock absorber tower nut 89558p01.jpg
      Fig. 2: The upper shock absorber tower is retained by the center nut (circled) and three surrounding nuts 89558p02.jpg
    11. Lower the rear axle carrier and remove the two bolts.
    12. Remove the shock absorber from the vehicle. To install:
    13. Install the shock absorber assembly onto the vehicle.
    14. Connect the brake hose and the ABS speed sensor to the shock absorber.
    15. Connect the stabilizer bar link to the shock absorber.
    16. Install the wheel and tire assembly.
    17. During installation, please observe the following tighten specifications:
      1. Tighten the shock absorber-to-body bolts to 29 ft. lbs. (39 Nm).
      2. Tighten the shock absorber-to-axle carrier nuts to 166 ft. lbs. (226 Nm) on 1988-91 vehicles and 188 ft. lbs. (255 Nm) on 1992-96 vehicles.
      3. Tighten the suspension support-to-shock absorber nut to 36 ft. lbs. (49 Nm) on 1988-91 vehicles. On 1992-96 models, tighten the stabilizer bar link to shock absorber retainers to 47 ft. lbs. (64 Nm).
    18. Install the rear seat back, vent duct and the package tray as required.
    Dec 18, 2010 | 1986 Toyota Camry
    Dear Sir, How do you change an 87 mitsubishi mighty max front shocks without any compression equipment? Please email me at brad8141@hotmail.com. Is there a book with instructions regarding this...
    1. Support the vehicle safely on jackstands. Support it at a height which will allow sufficient room to reach the upper shock absorber mount.
    2. Remove the wheel.
    3. Remove the upper shock nut, washer and bushing.
    4. Remove the lower mounting bolt(s) and remove the shock from the vehicle.
    5. Install the shock absorber in the vehicle and loosely tighten the upper shock absorber nut. Make sure the install the bushings and washers before installing the upper nut.
    6. For 4WD vehicles, install the shock absorber so that the white paint mark at the lower side of the shock absorber faces the outer side of the vehicle. Install the lower shock absorber bolt(s). On 1992-95 Montero torsion bar suspensions, tighten the single lower mounting bolt and nut to 65-76 ft. lbs. (88-103 Nm). On all other vehicles (whether torsion bar or coil spring suspensions), the two lower shock absorber mounting bolts should be tightened only to 7-10 ft. lbs. (9-14 Nm). Fig. 1: Install the shock absorber so that the white mark faces toward the outside of the vehicle - 4WD vehicles, except 1992-95 Monteros 86668006.gif
      Fig. 2: Install the bushings, washers and nuts in the order shown - except 1992-95 Monteros 86668007.gif
    7. On 1992-95 Monteros, tighten the shock absorber installation nut so that the dimensions shown in the illustration ( A and B) are at the standard values. These standard values are: A - 0.04-0.08 in. (1-2mm), B - 0.06-0.10 in. (1.5-2.5mm). WARNING
      When tightening the nut, be careful not to bend the stud pin of the washer assembly.
    8. On all other vehicles, once the lower mounting bolt(s) are tightened, tighten the upper shock absorber mounting nut all the way to the end of the thread on the shock absorber stud, then tighten the locking nut to 9-13 ft. lbs. (12-18 Nm).
    9. Install the wheel.
    10. Lower the vehicle to the ground. Fig. 3: When installing the upper shock nuts on 1992-95 Monteros, make sure measurement A is 0.04-0.08 in. (1-2mm) 86668008.gif
      Fig. 4: When installing the upper shock assembly, make sure its components are positioned as shown - 1992-95 Monteros 86668009.gif
    Nov 03, 2010 | 1987 Mitsubishi Mighty Max
    Need new struts on rear, Would like to replace with air shocks. Any suggestions on how I would do this?
    Shock Absorber -The rear already has air shocks on the 1999 Cadillac Deville: REMOVAL & INSTALLATION Rear
    1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
    2. Remove or disconnect the following:
      • Rear wheel Fig. 1: Exploded view of the rear shock absorber mounting 9300vg06.gif
      • Negative battery cable
      • Shock absorber electrical connector from the rear suspension support, If equipped
    3. Support the lower control arm with a jack to relieve the tension on the shock absorber.
    4. Remove or disconnect the following:
      • Lower shock absorber mounting bolt and nut
      • Upper mounting nut, retainer, and insulator
      • Shock absorber compress by hand and remove through the upper control arm
      To install:
    5. Position the top of the shock absorber with the insulator attached into the suspension support.
    6. Install or connect the following:
      • Upper shock insulator, retainer and nut. Torque the nut to 55 ft. lbs. (74 Nm).
      • Shock absorber lower mounting nut/bolt. Torque the nut to 75 ft. lbs. (102 Nm).
      • Shock absorber electrical connector to the rear suspension support, if equipped
      • Rear wheel
    Jul 29, 2010 | 1999 Cadillac DeVille
    What is service ride control
    Service Ride Control means one or some of your shocks or struts are worn and may need replacing. The price for new ones is not cheap,
    Jul 13, 2010 | 2006 Cadillac Escalade
    Rear noise vw passat 1996 tdi estate
    change anti roll bar bushes.Allso check coil springs are not brocken.
    Jul 04, 2009 | 1996 Volkswagen Passat
    Shocks
    rear
    5955ba5.gif ------------------------------------------------------------------------------------------
    front
    Removal
    1. Remove front shock absorber-to-upper shock bracket nut and bolt.
    1. Disconnect the lower end of the front shock absorber bolt and nut from the U-bolt plate.
    1. Compress the front shock absorber and remove.
    Installation
    1. Insert front shock absorber into the front shock absorber mounting bracket (18183). Insert bolt and tighten nut to 60-81 Nm (45-60 lb-ft).
    1. Attach the lower end of the front shock absorber to the U-bolt plate by installing the nut and bolt. Tighten to 60-81 Nm (45-60 lb-ft).
    front
    Feb 04, 2009 | 1996 Ford F350 Crew Cab
    How to take off & install front shocks on a 2002 Chevrolet S-10
    NOTE Hold the shock absorber stem with a wrench while backing the nut off.
    Wheel Mounting nut
    Retaining nut and grommet Shock absorber-to-lower control arm bolts Shock absorber Replace the parts, as necessary.
    0900c1528024dc58.jpg enlarge_icon.gifenlarge_tooltip.gifFig. Front shock absorber mounting-2WD vehicles
    To install:
    1. Fully extend the shock absorber stem, then push it up through thelower control arm and spring so that the upper stem passes through themounting hole in the upper control arm frame bracket.
    2. Install or connect the following:
      Retaining nut and grommet on the stem. Tighten the nut to 106 inch lbs. (12 Nm).
      Shock absorber-to-lower control arm bolts and tighten to 22 ft. lbs. (30 Nm) Wheel
    Oct 17, 2008 | 2001 Chevrolet S-10
    Frigidaire GLTF1670A Front Load Washer Logo
    24 people viewed this question
    Top Frigidaire Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    J. Bradshaw
    Archie Ferrarini
    Archie Ferrarini
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
