Question about Maytag PAV2300 Top Load Washer
Where can i find the model # on a maytag washer?
I have a top loader maytag washer and can't find the model #. Can you help?
    Scholar:
  • 105 Answers
  • Under the lid
  • On the back of the control panel
  • On the lower-front or side of the main cabinet body
Posted on Feb 10, 2009
the dr
  • 447 Answers
SOURCE: Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Posted on Sep 27, 2007
  • 4 Answers
SOURCE: Mayatag Atlantis Top Loader Washer Model MAV6451AWW
there are two clips about 3 inches in from the corners in the front between the top and front panel.you push a putty knife into the space between the top and front panel about 3in in from corners and lift the front of the top.
Posted on May 12, 2008
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
honeymokey
  • 3113 Answers
SOURCE: Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
Posted on May 17, 2009
  • 18 Answers
SOURCE: My maytag top loader washer won't spin but
Maybe a sock stuck between the two tubs. If it has not dropped down too far you maybe able to feel it. Open the lid and pass your fingers gently between the two plastic tub covers. The lower cover moves with the inner tub while the upper stays still.
Posted on Jun 21, 2009
Need to no how to getr in to the inner part of my washing machine. Is there clips holding? Will it pop open by pulling on it
If you are referring to a Whirlpool manufactured TOP LOADER (such as Kenmore, Estate, Roper, Frigidaire and some later model Maytags), the interior of the washer is accessed by removing the exterior washer case. The following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
Older Maytag and GE TOP LOADER interiors are commly accessed by locating the two retaining clip along the seam where the top panel meets the front of the washer (about 2 inches in from each side) and pushing in with a putty knife to depress. This releases the top and it can be lifted up. The access screws that hold the front panel in pace are now accessible and can be loosened to remove the front panel for full access to the interior.
If this is a FRONT LOADER, the interior is accessed on MOST models by removing the washer top panel. This is accomplished by removing the retaining screws that hold the top panel in place in the rear of the washer. This will allow access to the controls and dispenser. For access to the drain pump and drive components, you will need to remove the kick panel directly below the door. There are a series of retaining screws along the bottom front edge that hold the panel in place.
If none of these tips help, please post back with a MODEL NUMBER so that I may assist you further.
Jul 26, 2011 | Washing Machines
How to remove top cover
This particular model Maytag is manufactured by Whirlpool. The following link explains how to remove the exterior washer case on Whirlpool manufactured top loaders:
If you have any questions about these procedures, or need additional troubleshooting advice, please post back with your washer symptoms and let me know. I hope this helps you.
Apr 22, 2011 | Maytag Centennial MTW5800TW Top Load...
Maytag neptune top loader model fav6800aww has an error code od
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The pump is not pumping out the water so the cloths are wet when the cycle is finished.
No problem Helen I have to post as a solution to post console pic's
Take a look and see if your washer seems to be these models. If not maybe somone can help you. Don't vote for me if I can't help. I'm an owner like you.....Rich
Here are the two type of Maytag Top Loaders I can help with;
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a maytag top loader washer and when it is on the spin cycle the whole drum shakes hitting the walls of the washer
Without having the model number, it is difficult to diagnose.
Most Maytag / Whirlpool top loaders use a set of balance springs and friction pads to buffer the shaking.
Here is a Whirlpool site with a number of PDF files on their products including troubleshooting sections.
Find your washer under laundry products and open the PDF, it will probably take a few minutes to load.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1
Sep 27, 2009 | Washing Machines
May 17, 2009 | Washing Machines
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
May 12, 2009 | Maytag PAV2300 Top Load Washer
Sep 27, 2007 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
