Question about Aiptek ISDV2.4 Flash Media Camcorder
I can't get flash to work on my camera
It keeps saying "Strobe Charge"
    Problem Solver:
  • 5 Answers
Make sure you have good strong batteries. "Strobe Charge" is what the camera says when it's sending power to the strobes that make the flash. It can take alot of juice and if you're using weak or old batteries they may not be able to handle the load. I found with my DSLR that the Energizer Lithium batteries are great for cameras and have been using those exclusively in all my cameras. I just got the Aiptek about a month ago, have not changed batteries yet. My other digital video camera ran for over two months on one set of them, and I used it alot. It's on it's second set now and my husband has it.
Posted on Mar 05, 2009
Hi, If I connect my external flash to my Canon 7d & switch it on! but switch of in my Camera settings, will the Focus beam on my flash assist AF within the Camera? I was told this works with the 5D...
Hello Adrian G Ellis,
The Intova ISS2000 is a slave strobe that does not have TTL or focus beam function. It is a manual strobe that has power level function only.
Aug 24, 2013 | Intova Iss 2000 External Flash
I have a Canon Powershot SX10IS. My flash is set "On" but will not go off and allow me to take a photo. Can flashes "Burn out?" If so, can I get a replacement?
Hi,if you set the flash on and still not working, your strobe unit is damage and need to be replace.bring to service center and for sure there's a replacement parts for your camera. Strobe unit compose of capacitor and once the said parts is damage the flash will not work anymore.
good luck and thank yo
Aug 10, 2010 | Canon PowerShot SX10 IS Digital Camera
My flash don't work at all when i turn it on a
1.if you can open and reset the connection of your strobe unit of flash unit inside.
2.the strobe unit or the capacitor of your flash need to replace.
3.need to rbing to service center
Jun 03, 2010 | Olympus FE-46 Digital Camera
Canon 580ex II strobe issue
This depends on the mode you have selected on the flash gun. If you have Multi selected you will get the strobe effect. The strobe effect is all so present to help the flash set the correct exposure. It's not a problem with the flash or the camera. Spend some time reading through the flash gun manual. I have to admit it is not always clear. Also try Youtube for a video.
Sep 21, 2017 | Canon Speedlite 580EX II TTL Flash
Ttl auto does not work
Digital Camera Fully Compatible, Newly Developed S-TTL System "S-TTL" enables TTL auto shooting by an external strobe for a digital SLR camera as well as for a point & shoot digital camera.
INON S-TTL auto strobe supports any manufactures' model providing highly accurate exposure control.
Film camera era without strobe selection problem TTL stands for "Through The Lens" and TTL auto strobe system controls flash amount to provide correct exposure based on calculation by camera's internal sensor metering reflecting strobe light from a subject through the lens. This TTL system meters actual light amount reflecting from a subject providing accurate exposure.
When we start with the history of underwater TTL auto strobe, underwater camera?"NIKONOS V" released in 1984 was the first to provide automatic TTL flash control for underwater strobe SB-102, SB-103 succeeded by NIKONOS V compatible underwater strobes form other manufactures. The 5 pin electrical sync connector for NIKONOS V is most popular and widely adopted to connect an underwater strobe and underwater film camera (underwater camera/housing).
A film SLR camera has flexibility to select an underwater strobe. As far as housing has NIKONOS type electrical sync connector and properly wired, automatic TTL flash control is usable with any TTL auto strobe like Nikon SB-105, INON Z-220, Z-22 connected via electrical sync cable.
NIKONOS type 5 pin electrical sync connector and NIKONOS V with INON Z-22 strobe
Film camera compatible strobe is not usable for a digital camera!? Underwater TTL strobe circumstances have been drastically altered with the spread of digital camera among divers. Some underwater housing for digital SLR camera has NIKONOS type electrical 5 pin sync connector as same as film camera housing. Since the housing has same NIKONOS type sync connector, existing film camera compatible underwater strobe has been considered compatible with a digital SLR camera via 5 pin sync cable but happened to experience error message on the digital camera or blackout on an image even the strobe worked. Why this happened?
This is because automatic TTL strobe system difference between a film camera and a digital camera.
The film TTL auto system makes single flash while digital TTL auto system employs pre-flash type making two to three flashes. Film TTL auto strobe system starts firing at the same time the shutter opens and reflecting strobe light from a subject is recived at a film. The reflecting light on the film is metered by the sensor to determine when to cease firing for correct exposure. This process takes only about 1/1000 second.
In contrast, digital TTL auto strobe system can not calculate adequate exposure based on reflecting light from a subject since image sensor (CCD/CMOS) reflectivity is comparably low comparing to a film. So digital TTL strobe system gives preliminary flash for very short period of time (pre-flash) just before the shutter opens metering reflecting light from a subject by the sensor to calculate necessary amount of light for correct exposure and starts emitting main flash at the same time the shutter opens. Canon E-TTL and Nikon i-TTL employs this system.
When we connect conventional film camera compatible TTL strobe to pre-flash type digital SLR via sync cable, the strobe makes full dump by pre-flash signal then the shutter opens before the strobe has been fully charged resulting in quite under exposed image only with ambient light. Even two time flash compatible strobe like INON Z-220 strobe, does not fully support a digital TTL and force to use Manual flash mode.
Film SLR:
A strobe starts firing at the same time the shutter opens and quenches firing when correct exposure has been obtained.
A film compatible TTL strobe connected to a pre-flash type digital SLR via electrical cable flashes does not support TTL auto exposure resulting in synchronization only with first pre-flash or totally uncontrollable.
The birth of digital fully compatible S-TTL S-TTL auto compatible INON D-2000 strobe and Z-240 strobe works in TTL auto mode by simply setting their main dial to S-TTL position. A film camera seems to depend more on photographer's skill, experience and feel since the camera does not allow checking images on site. A digital camera allows us to check images right after shooting and enable to try to shoot again as much as we like. And high capacity memory card further allows to shoot hundreds of images. The digital camera makes entry level of underwater photography getting down and nowadays more people buy a digital SLR camera and underwater housing even they have just started underwater photography. However underwater photography gets more difficult because underwater strobe does not work in TTL auto.
INON is among the first to support digital TTL auto system with "S-TTL" auto mode equipped D-2000 strobe and Z-240 strobe.
The proper name of S-TTL is "Optical Synch TTL". S-TTL enables to perform in TTL auto exposure as same as genuine TTL strobe from camera manufacture, based on camera's built-in flash light to use as a signal to be transmitted to a strobe. S-TTL uses digital camera's built-in flash light not as a light source but as like a controller to trigger S-TTL strobe.
The built-in flash of a digital camera makes weak flash (pre-flash) before main-flash to calculate exposure. This pre-flash is transmitted to S-TTL strobe to control the strobe to make pre-flash to a subject. The reflecting light from the subject goes through the camera's master lens to an image sensor then a processor calculates main flash light amount for correct exposure.?Finally the built-in flash makes main-flash which is transmitted to the S-TTL strobe to cause main-flash of the S-TTL strobe.
Digital camera's built-in flash lights are transmitted via an optical fiber to the
S-TTL strobe to make pre-flash and main-flash instead of the built-in flash.
Apr 30, 2010 | Olympus FL-20 TTL Flash
When i try to use flash it just says strobe charge
Before the flash can work, the strobe have to be charged. as soon as that is done it well say ready.
Feb 02, 2010 | Aiptek ISDV2.4 Flash Media Camcorder
Camera does not flash
problem is with the high voltage capacitor charge circuit. the internal battery voltage is stepped up to around 4 thouseand volts. this voltage is necessary to jump the electrode gap inside the xenon strobe tube which is the flash component
Sep 02, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
580ex not flashing at all
after using it many flashes at 1/1 power the strobe doesn't work anymore
Jun 19, 2007 | Canon SPEEDLITE 580EX TTL Flash
Studio Strobe not firing with Coolpix
The Coolpix line of cameras require a "tip positive" sync connection to an external strobe unit (when using the Nikon AS-15 Flash Sync Adapter). On some external Studio Strobe units the sync polarity is easy to change because of the type of plug: On this type of connector simply turn the plug around and insert it with the male pin connectors in the other holes. Other types of connectors (such as the standard "phono" plug) are not generally changeable by the user. If the Coolpix does not fire an external strobe check with the strobe manufacturer for sync polarity info.
Aug 30, 2005 | Nikon Coolpix 5000 Digital Camera
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Open Questions:
Aiptek ISDV2.4 Flash Media Camcorder Logo
132 people viewed this question
Top Aiptek Video Cameras Experts
tomikles
Level 1 Expert
prouddad_1
Are you an Aiptek Video Camera Expert? Answer questions, earn points and help others
