Hi all,I have a 10" Rockford series 1 subwoofer tube,drive by a new ORION XTR 475 amp.The set up is that the subwoofer tube is driven by CH3/CH4 bridged. Problem is that the CH 3/4 power supply of the amplifier always damaged.This happen many times after the unit turn on for about 1 hour.The heat sink temperature at that time is quite acceptable,about 50-60 C. I wonder if its a heat problem and building a fixture with 4 cooling fans.2 for the heatsink frm above. Also the back cover of the amplifier is removed and vent by 2 cooling fans from the bottom.I hope this will cure the problem. Meanwhile I also wonder if this subwoofer setup is too hard for this amplifier. Have you heard this kind of problem before and any idea ? Bye.
I agree. I find that my 425 has a very generous power supply. Hasn't failed on me yet. Nor has my friends 2150XTR.
Explain how these are "weak". What inside them makes them weak. Do they use to small of power transistors at the power output stage? Let me know, I'm sure you know EXACTLY what you are talking about.
(Tony the Tiger) wrote:
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on Orion amp problem ????:
Solution #2
posted on Aug 01, 2007
herself - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Orion amps have small power supplies? My NT 100 has huge power supplies Also, the type of power supply is important aswell. Anything that is Orion, XTR,HCCA,Concept and NT are extremely well built, some say overengineered, and I can assure you that the power supplies are more than adequate. Considering the fact that the power supply is blowing repeatedly tells me that the problem is elsewhere, as I said the power supplies are more than adequate.
John Angelotti < <>...
Solution #3
Jimmy NY - usenet poster
As I have said before... The ORION amps have very small power supply's in them... This makes the amp have to work much harder to get the same power as one with a bigger power supply.. That is why you are blowing it... The fans should help but what you might want to try doing is turning down your gain... Remember, the gain is NOT a volume control for your amp. I know a lot of people who think it is... Give it a shot and see what happens...
Solution #4
Lizzy - usenet poster
Are you sure it's the power regulator dumping the heat???
I believe that anyone worth his salt can design a switching power regulator that can protect itself. The advantage of switchers after all is the lack of correlation between power and size, their efficiency, and the voltage boost we need in the 12V world. Smaller supplies are designed daily by doubling the switching frequency or just by using surface-mount components.
Power supplies have a circuit called "foldback protection" which actually lowers the supply voltage to limit the maximum current and overheating that can be drawn under normal operation. "Working harder" should be limited to the audio output section.
One thing that can drive a switcher into oscillation and overheating is resistance and impedance in the ground wire preventing the input filter from dumping noise, or a manufacturing/component defect.
I can't tell that from here without looking at it. But, Orion does have a web page... #
Ultimately, switching power supplies use Class-D circuitry and may even use IGBT mosfets[1] which translates into heat dissipation you won't be able to feel.
IGBT: *VERY* low turn-on resistance and heat dissipation for a transistor.
Rob
Solution #5
Bomber - usenet poster
John Angelotti < Maybe you should tell that to Richard Clark :o). If I remember right, he had motors attached to the gains of the amps in his GN that physically turned down the gains of the amps with either the volume control or the noise gate (or maybe it was something else; it was a while back and I'm working on memory). Does anyone else remember this or have I been smoking too much crack? :o)
Aric
Solution #6
Reynolds - usenet poster
Ass I have said before... The ORION amps have very small power supply's in them... This makes the amp have to work much harder to get the same power as one with a bigger power supply.. That is why you are blowing it... The fans should help but what you might want to try doing is turning down your gain... Remember, the gain is NOT a volume control for your amp. I know a lot of people who think it is... Give it a shot and see what happens...
