I have a Tevion TDR251HD DVD Recorder 250GB and HDMI Output. The Remote just stopped working. It hasn't been dropped and it has fresh batteries. The unit works with pushing the buttons but I cannot record to or olay from the hard drive without the remote. How do I tell if it is the remote sensor is which has failed or the remote itself? And where can I get a new remote?
  • 1,800 Answers
If u want to check if ur remote is not the faulty part in this issue please put a new fresh batteries and take a camera device(mobile phone,digital camera and start pushing buttons on the remote pointing it to the camera LENS and check if u ca see the Infrared reflection on the LCD.
if the remote is not emitting the infra light from the sensor through the lens. that means the remote controller is defective: try universal remote or ask for a new one.
if the remote is working and u r not getting response from the Tevion that means the DVD Player Sensor IS defective and u need a replacement in this case maybe for the whole Part IC.
Posted on Feb 10, 2009
    Master:
  • 848 Answers
Hi
remote sensor is failed ...you need to buy new one ....
    Brigadier General:
  • 3,614 Answers
better to buy a new remote for that, instead of repairing it.
  • micromaster
    micromaster Feb 10, 2009
    you can order HERE
    hope this initial info, helps you.
Need directions for a tevion tdr251hd remote
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 21, 2013 | Televison & Video
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
    Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
    Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
    Mar 28, 2010 | Sony RDR-GX7 DVD Recorder
    No hdmi funktion to my new LED TV.
    Most likely the output from the Pioneer is not compatible with the TV.
    Try resetting the output by holding Stop (on the pioneers front) and press the Open/close button. This will reset the output signal. Also, if the harddrive in the Pioneer is defect, the HDMI signal will not output.
    Jan 12, 2010 | Pioneer DVR-550HS HDD Recorder
    Can't eject DVD from our Tevion TDR251HD recorder.
    The only way I guess that you could do this is if you take the cover off of the DVD player and remove the DVD from the tray that supports it. There should be some Phillips screws (or other type) on the top, back, front, sides, or bottom of the DVD player. Unscrew them, remove the cover, and try to get the DVD out. You may have to unscrew a circuit board if there is one over the DVD tray. Make sure that the power is OFF and the unit is UNPLUGGED before you try anything! This is the only way that I know of that could solve your problem.
    Jul 29, 2009 | Televison & Video
    Tevion DVD - Hello on digital screen
    I think it may be a good idea to take it back to the shop where you purchased it.
    Dec 30, 2008 | Televison & Video
    We have a tdr 930 tevion dvd recorder...we have lost the remote so the thing wont work..we have tried a universal which worked on everything but the tevion dvd recorder.... HELP PLEASE roy... ...
    we have a tdr 930 tevion dvd recorder...we have lost the remote so the thing wont work..we have tried a universal which worked on everything but the tevion dvd recorder....
    HELP PLEASE jeremy ...hawkwing1@hotmail.com
    Aug 26, 2008 | Televison & Video
    Tevion player shows BAD DISC,
    Since the unit is under warranty, you can't touch anything without voiding the warranty. This problem could be as simple as a dirty lens. Bring the unit in for repair under warranty.
    Dan
    Mar 19, 2008 | Televison & Video
    Televison & Video Logo
    47 people viewed this question
    Top Televison & Video Experts
