SOURCE: vw golf has had diagnostic check found fault code P0023
This trouble code is related to a faulty camshaft sensor or to be more precise the camshaft position actuator circuit is open. There are 2 camshaft sensors on the Golf and the camshaft sensor that this code relates to is behind the timing belt. This code indicates that the solenoid that adjusts the cam timing has an issue - the circuit is open. The actuator itself may be faulty or if you are lucky it may be wiring related or be a bad connection to the actuator.
