Question about LG Shine KE970 Cellular Phone
I can only turn my phone off and on
Although the end call button work, no other button including the side volume, home, and camera buttons work. My shine does not even acknowledge a button is being pushed. I can only answer phone calls if my phone is closed previous to the call and I slide it open. I still recieve text messages and voicemails, but I cannot hear them or open them. I just recieved this phone Friday to replace my Shine that had a cracked screen. The Shine was not dropped or anything. I took a nap with my phone on my bed stand and woke up to the problem. Please help me!
  • 1,800 Answers
These problems occurs when the flex cable is defective.
its the part that connects keypad to lcd.
replace it!!
plz rate this post.
Posted on Feb 10, 2009
My tablet froze it won't even let me put the password what can I do ?
Remove the battery.
Wait for 5 minutes.
Check your phone-sim and memory-sim is inserted correctly.
Replace the battery.
Try one of the following immediately after you turn on the power and while the power comes on...
  • Combination 1 - Volume Up + Camera button.
  • Combination 2 - Volume Down + Power button.
  • Combination 3 - Volume Up + Power button.
  • Combination 4 - Volume Up + Home + Power button.
  • Combination 5 - Volume Down + Volume Up + Power button.
  • Combination 6 - Home + Camera button.
  • Combination 7 - Home + Power button
Combination 2 has worked for me in the past, but it depends on your Tablet type and model.
Feb 24, 2015 | Samsung Galaxy S3
Tip
Hard reset for Nokia,HTC,BlackBerry,Iphone,Sony......
Hard reset is an operation that turn the device into default manufacturer,like the first use a new phone, it will wipe and delete all of your software,data,sitting and virus. if you can't turn on or process device sitting,You still can do the hard reset by instruction below,hope it will help you......... All Hard reset process need to turn device off/except iPhone4 .Make sure that ur phone is full battery and turn off,you can release the battery if necessary.... HTC/Windowsmobile =>press and hold volume up and down,including press power on/off button.you will see an automatic operation press volume up to hard reset or other to cancel./was tried on HD2 and Touch2,work very well. HTC/Android =>While turn off process,hold home+back button,including power button.then release home and back button,you will see an android hard reset operations and follow the in struction... IPhone 3G,3Gs, IPod Touch,IPad... =>- Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously . - Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart . You may release all button when you see the silver Apple logo . For IPhone4 is no need to turn off as normally =>-press and hold on/off+sleep/wake button to turn off,until see an automatic operation -slide across the red slider -hold two button above to turn on... * Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen . Nokia/Touchscreen with keyboard/N97,N97 mini,... =>Press and hold button shift/left+space+backspace,including power button and follow in struction... Nokia Touchscreen nonkeyborad/5800,5530,5230,5233,5802,X6,C6... =>Press and hold green+red+camera shot button,including power on/off until boot up./was try on Nokia 5800 and 5530,no problem.... * for N8 =>press volume down+camera+menu,including power button... Nokia nontouchscreen/N70,N71,N80,N95,N96,N82,N95,E52,E71E71x,E72,6300,5320,5220,5130,6120,6303,6500,6730,8800....../S60 =>Press and hold green,*,3 button,including power on/off button.../was tried on Nokia N81 and,no problem,work very well. * For Nokia,if the operation require code,the default code is 12345. * S40 is not available hard reset by button.can do by type *#7370#,and available for S60 too. BlackBerry =>Press and hold Alt+Shift/right+Del,then follow the instruction... SonyErisson/Touchscreen with keyboard =>Press and hold right + left soft key,including press power button.../was try on X1i,no problem... SonyErisson/Nontouchscreen: Not available hard reset by button...need the future research. You should know that Hard reset is the last solution,if none solved ur mobile problem. Note: all above just a part and not 100% correct.No guarentee for data lose or any demage.Do by your own risk -kindly do not edit this document.... :) Research and Prepare by YEKCHHUNHOUR. Inform me if you see any wrong instructions,to improve this doc better and confiding. Via Email: Chhunhour.kh@hotmail.com 27/12/2010
on Jan 01, 2011 | Cell Phones
Tip
Any phone Hard reset
HARD RESETHard reset is an operation that turn the device into default manufacturer,like the first use a new phone, it will wipe and delete all of your software,data,sitting and virus.if you can't turn on or process device sitting,You still can do the hard reset by instruction below,hope it will help you.........All Hard reset process need to turn device off/except iPhone4 .Make sure that ur phone is full battery and turn off,you can release the battery if necessary.... HTC/Windowsmobile=>press and hold volume up and down,including press power on/off button.you will see an automatic operation press volume up to hard reset or other to cancel./was tried on HD2 and Touch2,work very well.HTC/Android =>While turn off process,hold home+back button,including power button.then release home and back button,you will see an android hard reset operations and follow the in struction...IPhone 3G,3Gs, IPod Touch,IPad...=>- Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously .- Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart . You may release all button when you see the silver Apple logo .For IPhone4 is no need to turn off as normally=>-press and hold on/off+sleep/wake button to turn off,until see an automatic operation-slide across the red slider-hold two button above to turn on...* Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen .Nokia/Touchscreen with keyboard/N97,N97 mini,...=>Press and hold button shift/left+space+backspace,including power button and follow in struction...Nokia Touchscreen nonkeyborad/5800,5530,5230,5233,5802,X6,C6...=>Press and hold green+red+camera shot button,including power on/off until boot up./was try on Nokia 5800 and 5530,no problem....* for N8 =>press volume down+camera+menu,including power button...Nokia nontouchscreen/N70,N71,N80,N95,N96,N82,N95,E52,E71E71x,E72,6300,5320,5220,5130,6120,6303,6500,6730,8800....../S60=>Press and hold green,*,3 button,including power on/off button.../was tried on Nokia N81 and,no problem,work very well.* For Nokia,if the operation require code,the default code is 12345.* S80 press and hold Ctrl+shift+F* S40 is not available hard reset by button.can do by type *#7370#,and available for S60 too.BlackBerry=>Press and hold Alt+Shift/right+Del,then follow the instruction...SonyErisson/Touchscreen with keyboard=>Press and hold right + left soft key,including press power button.../was try on X1i,no problem...SonyErisson/Nontouchscreen: Not available hard reset by button...need the future research.You should know that Hard reset is the last solution,if none solved ur mobile problem.Note: all above just a part and not 100% correct.No guarentee for data lose or any demage.Do by your own risk-kindly do not edit this document.... :)Research and Prepare by YEKCHHUNHOUR.Inform me if you see any wrong instructions,to improve this doc better and confiding.Via Email: Chhunhour.kh@hotmail.com27/12/2010 VOTE FOR ME PLZ..........
on Dec 31, 2010 | Lands Phones
Forgot pattern need to unlock it
Hard Reset LG Optimus GT540 100% working method
You can use this technique to solve
= Remove Wrong trials in entering password
= account blocked and no access to menu
= to remove all your data from phone
= to remove viruses or malware application
= to speed up your device.
LG Optimus GT450 Hard reset is easy and can be done by anyone.
Follow this easy steps
1) Start your phone [phone must be started with or without sim]
2) Press volume up button + home button + search button
[Location of volume up button is on right side, location for home button is on bottom middle button of home screen and search button is right side of phone above camera button]
3) Keep all those button pressed at the same time for 5 second
4) Phone will ask you for " Are you sure you want to factory reset?"
5) Press yes and wait for 1 minute, Phone will hang first and than restart after sometime.
6) You've done resetting your GT540 successfully
Be careful, This trick will Erase / Format all your private data including contacts SMS and other things.
Jul 06, 2014 | LG GT540 Cell Phone
Motorola mini defy wont load only motorola shows
How to hard reset:
Warning! All data will be lost!
1.Power off your phone
2.Press together volume up + volume down + power button until recovery menu appears
3.Select "recovery" with volume buttons and press camera button to confirm
4.Press home button when Android logo appears
5.Select "wipe data" with volume buttons and press camera button to confirm
6.Select "yes" and press camera button to confirm
7.Wait until format ends
8.Select "reboot" and press camera button to confirm
9.Wait until phone restarts
That's it!
- See more at: http://factory-reset.blogspot.com/2013/09/motorola-defy-mini-xt321-hard-reset.html#sthash.eUfAgbLd.dpuf
Jan 31, 2014 | Motorola Mobility Defy Mini XT320 Black...
How do you turn it on
Below the display are three physical buttons: Back, Home and Phone (sound familiar?) The left side has a volume rocker and camera button, while the right houses the power/lock key, 3.5mm headset jack and microSD card slot.
It's on the right side of the phone. Looks like the volume on the left side. On the right side, one is lock and the other is power.
Hope that helps :D
Sep 21, 2011 | LG RUMOR Cellular Phone
My LG Android GT 540 had too many patterns drawn wrongly. now it is locked and it is asking to unlock it with my google account. How do go about this?
Hard Reset LG Optimus GT540 100% working method google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad); You can use this technique to solve
Dec 31, 2010 | Cell Phones
LG Vu Button Issue
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Apr 05, 2009 | LG Vu CU920 Cellular Phone
Washed my phone
your lucky the phone turns on - it is water damaged - if you want to fix it try to buy a broken one from ebay to get the parts.
Jan 19, 2008 | Samsung SYNC SGH-A707 Cellular Phone
LG Shine KE970 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
