Question about Belkin Bitronics Data Switch Kit [ F1U123-KIT ] (108998)
Connect to Konica photo copier/prtr with Belkin F1B024-E switch
I want to connect 2 computers to share a Konica photo copier/printer, using a Belkin F1B024 A/B switch. I tried it and it doesn't work. Do I need special cables?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 18 Answers
If you're using a utp straight through cable, just connect your 2 pc to your switch then install supporting software to both pc.. then go to control panel then printer and faxes and find printer..
Posted on Feb 11, 2009
Network a Konica Minolta printer
FILE SHARING BETWEEN COMPUTERS ON A NETWORKBasicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.SETTING UP A SHARED NETWORK PRINTER
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5.Right click on the printer - click Properties - click Print Test Page toconfirm printer installation.
Jul 27, 2012 | Konica Minolta Office Equipment & Supplies
Can I connect 2 computers sharing a KVM Switch to 1 USB printer?
You need a USB printer share device such as this one http://www.amazon.com/IOGEAR-2-Port-Printer-Sharing-GUB211/dp/B001SEB45M/ref=sr_1_1?ie=UTF8&qid=1328912939&sr=8-1
Feb 10, 2012 | Brother Office Equipment & Supplies
Can the HP PSC 2410 printer be shared between 2 computers?
generally the printers with single USB port are dedicated for use with one computer.
However, depending on the way you connect the computers you can share the printer with more than one computer.
1. SET THE SECOND COMPUTER UP AS A NETWORK PRINTER
This is one of the most common ways to connect two home computers to the same printer. The advantage of this technique is that it doesn't cost you anything extra. You do require some computer literacy in networking though.
Firstly you physically connect the first computer to the printer via the provided cables. The second computer now needs to be set up as a network printer to have printing capabilities. The computer not physically hooked up sends a message via the network to the computer which is physically connected to print.
To set up the network connection in Windows follow these steps:
-Open the control panel
-Select the network or network and sharing icon
-You should see an icon named file and print sharing or simply print sharing. Turn on printer sharing if it is off.
(This requires your two computers to already share a network connection; otherwise you will have to set this up).
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/print_sharingw.mspx?mfr=true
2. PURCHASE A PRINTER SWITCH
A simple old fashioned way to connect two computers to one printer is by hooking them up to one switchbox in the middle. This switch is what is connected to the printer. This is a similar method to using a router to distribute the Internet to more then one computer.
This method is good for people who aren't very computer literate when it comes to networking. All you have to do is plug the cables in and off you go. However, it has one large disadvantage which is that the computers and printer all have to be in close proximity for the cables to reach.
The printer server should support the printer so that you can get maximum functionality from the printer device (including the multifunction feature).
http://cgi.ebay.com.au/Gray-Steel-Two-Ports-Printer-Sharing-USB-Switch-Box-/180502082365?cmd=ViewItem&pt=AU_Computers_Printer_Accessories&hash=item2a06c3333d
3. You can buy a printer server but for that you need to make sure the device fully supports the printer you have got including the multifunction features. Both computers will need to have network connection.
Something like http://www.netgear.com.au/au/Product/Print-Servers/Wired-Print-Servers/PS121
or
http://www.belkin.com/IWCatProductPage.process?Product_Id=354892
May 07, 2010 | HP PSC 2410 All-In-One InkJet Printer
Printer drivers
Have you made sure that the Printer is a shared resource.
Generally a printer will not be seen on a network if it is shared (allowed to be used by others).
From the computer (where the Printer is attached), locate the Printer by :
1. Click Start
2. Click Settings (or Control Panel)
3. Click Printers (or Printers and Faxes)
4. Highlight the printer you want to share.
5. Click File, Sharing (or Properties, and the Sharing tab).
6. Click to Share the printer.
The printer should now be available for you to see (from your laptop or anything connected to your network). The instructions above are for Windows XP (Vista).
I personally do not own Windows 7 and cannot provide you with exact steps for Windows 7.
However, SHARING is what you are looking for. If you can't achieve sharing the printer with the above steps, then use the HELP in Windows 7 to get the exact instructions.
If you need further assistance, let me know. Please rate. Regards,
Feb 16, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Computers not recognizing printer
Check the router or whatever hardware you use to connect the 4 computers to the printer. I use a USB Share Switch for 2 computers and 2 printers. Switch can be found at Amazon.com and other vendors.
May 29, 2009 | Epson Stylus CX9400 Photo Printer
Can I share 1 printer with 2 computers 1 Vista 1 XP with the hub?
Yes you can share out one printer from 2 computers. you can either set up a home network using arouter to connect your 2 computers. Or you can use an a /b switch to share the printer.
Nov 21, 2008 | Belkin BLKF5U201 USB Peripheral...
Connect mulitple Computers to one printer
Is your computer is networked or connected to each other? if its networked then you can use network printer sharing.
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
May 07, 2008 | Office Equipment & Supplies
Setting the IP address on Konica 7030 multi-function copier
if you don't have a netwok card in you Konica 7030 then you have to connect it to your computer over LPT cable or USB Cable then install the software from the Konica 7030 CD.
after that you can Share the installed Konica 7030 Printer and map it at the other computers.
Try and feed back...
Regards
May 03, 2008 | Office Equipment & Supplies
Moving a Belkin Data switch F1B024-E
It All Depends Sometimes You Have To By A Dynamic Switch Where You Can Find It At Walmart To Be Able To Run More Then One Thing Also You Might Want To Uninstall And Reinstall Your Printers Because A Containing File Could Have Gotten Corupted! Please Mark How Helpful I Was ! Thanks And I Hope This Helps!
Nov 02, 2007 | Belkin Data Transfer Kit (F1B024-2E)...
Computers & Internet Logo
161 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
