Question about Toshiba Satellite 2250XCDS Notebook
Cange a hard drive
How big of a hard drivewill asatellite 2250xcds/6.0 take
  • 180 Answers
As far as physical dime"nsions, it will only take the 2.5" hard drives. As far as how much in GB it can handle, I see no limitations other than those by the OS. If you're running XP, you'll be safe with whatever is on the market. Get as much as you can afford!
Posted on Feb 10, 2009
I formatted the hard drive connecting it directly to the computer (using Windows XP). Then when i reassemble the Ethernet Big Disk, it turned on but it doesn't do anything. My question is: Is the...
the OS of the Ethernet Big disk is on the hard drives, so you did erase them. This unit should only be formatted using the administration page drive format option.
LaCie usually does not give away the OS, so your option would be to close some other Ethernet Big Disk or Ethernet Disk Mini drives unto your now formatted drives.
Jan 05, 2011 | LaCie (300966U) 1024 GB Hard Drive
Hello everyone, i have a problem with my Verbatim smartdisk. Before I formate it, it was in Fat, had 2 partitions and 250 Gigabyte. After formatting, there is only one partition in NTFS and has only now...
Click Start
RIGHT-click "My Computer".
Click Manage.
Click Storage.
Click Disk Management.
Click to delete one partition on the disk-drive.
Click to delete the other partition on the disk-drive.
Click to create one partition on the disk-drive.
Format the partition.
Dec 27, 2010 | Verbatim SmartDisk Firelite Portable USB...
The hard drive died, can I install Western Digital Scorpio Hard Drive - 120GB - 5400rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE - Internal (WD1200BEVE) to replace it
You should definitely try out if it fits inside the bay first.
The original drive in the M55-S135 has a height of 8mm and the WD1200BEVE is 9.3mm. This is not a big difference and may pose no problem, but you would like to have all covers close properly later, I assume.
Other than the slightly larger physical dimensions, the drive should be fully compatible with the laptop.
Feb 12, 2010 | Toshiba Satellite M55-S135 Notebook
How do i cange a clutch on a renault scenic
big job. takes alot to explain. you will need to get fitting manual. but if you dont know alot about cars i would leave it with a mechanic.
Dec 16, 2009 | 2005 Renault 18I
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
Jun 22, 2009 | Kingston Technologies 512MB DataTraveler I...
T60p does not recogonise hard drive
if you are trying to install XP on (what i assume to be) a new computer, your XP install CD does not have the SATAcontroller drivers built in.
you need to go to the vendors homepage and see if there are drivers available for the controller for XP. sometimes in the cases where the computer comes with Vista there will not be any xp controller drivers available at all.
May 28, 2009 | IBM ThinkPad T42 Notebook
Laptop Freezes
it sounds like the memory may be at issue as it heats up it dies, then cools down.
if you have 2 sticks of memory take one out and see if it will run.
if not switch to other stick.
if still not running remove all memory as the system should have 64 meg of onboard non removeable memory .
as per this google :
Memory Upgrade for Toshiba Satellite 2250XCDS, the Toshiba Satellite 2250XCDS takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory.
windows may not boot and run at all with 64 meg so you can enter the bios screen and let it sit there,
instead of trying to unplug the system to kill it just hold the power button for 10 seconds and it should die.maybe.
Apr 30, 2008 | Toshiba Satellite 2250XCDS Notebook
D Drive / E Drive
try to cange cable if not buy new unit 20 bucks pop in easy they fail often thx nick
Feb 04, 2008 | Maxtor Hard Drive
Toshiba Satellite 2250XCDS Notebook Logo
99 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
