Question about Panasonic DP-150FX Laser Printer
The Fax and photocopy features works but printer don't print.
It receives and send fax, print the fax, does photocopies but it doesn't print. I've noticed the data light is on solid.
What can I do to fix the issue.
  • 2,120 Answers
Unplug the power cord for 10 seconds.
Posted on Feb 10, 2009
How should i set my printer
Copy & fax not working?
Does it print & scan?
Mar 20, 2014 | HP Officejet 4500 Wireless All-in-One...
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're want the fax you must check the you're photocopy machine have a fax want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
Fax won't transmit or receive
you need to flush the memory of the fax in the settings, some faxes machines depending on the grade or type can hold between a few MB up to 64 MB or more with expansions. Corporate photocopiers or bigger machines have an internal hard drive to store the data.
Just go through the settings and look for something that will let you empty the logs of the faxes that were received and send.
Also most of the all-in-one machines have a web interface if they support Ethernet (network) connection where you can perform those task in a more easier manner.
Feb 26, 2013 | Canon imageCLASS MF5730 All-In-One Laser...
How to receive fax documents
You cannot receive fax using this printer, because this printer doesn't support fax sending/receiving. Only fax supported printers can receive fax documents. You will know if a printer is fax support if you see a Fax button there or if you can see a numpad buttons where you can dial numbers.
These are the photo examples of fax printers
Hope my solution helps. Thanks for using Fixya!
Jul 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Incoming fax does not print, and also cannot get printout of faxes received. Memory was received. Regular printing and photocopying works fine.
if you found the msg on lcd like "toner empty" & red light near the lcd
then you have to reset toner counter through tech mode.
MENU # 1 9 3 4 MENU pres continues you will find tech mode on lcd
then press 3 times right arrow key "new cartridge" will come on lcd bottom line
then press 2 times ENTER button & swicth of the macine for 5 second then on
all samsung mfds stop printing FAX when "TONER EMPTY" msg comes.
Feb 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Epson Stylus NX300. I send a FAX and the folks on
check first if your printer can copy well. try to photocopy a document. and if it copies well, that means, its a problem on the part of the receiever, if it does not copy well, that means the scanner of your unit has a problem.
Feb 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Panasonic DP 180 - will not print faxes
you need to do an all job clear in fax mode. leave me a msg and i will try to help
Oct 04, 2008 | Panasonic Workio DP-190 Multifunction...
Panasonic DP-150FX Laser Printer Logo
76 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
