Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
Amana top loading washer-weak agitation for 1-2 minutes then fine
I suspect the timing control is getting defective. About 8 months ago we experienced this for a few days and then it disappeared until recently.
Is this a typical symptom of a timer/sequencer going bad or is this more likely another issue?
Thanks
Steve
  • Anonymous Mar 20, 2014
    Working normally until 2 days ago now only reads 1.03 for time and key on top right hand side of control pad keeps flashing!!!
    President:
  • Amana Master
  • 2,651 Answers
Weak agitation ??? i would not suspect timer, i would first check your dial settings, moakin sure a knob has not been changed to gentle/gentle. instead of normal /normal.. if that is not it, i would perhaps, look into tenson of belt or a faulty brake(common if brake pads fail there is no "resistance" on hte wash.. you can check this by removing the lower acess panel and look for broken peices of brake pads, under the unit. similar to car brake pads
Posted on Feb 12, 2009
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
Will spin but not agitate LWA40Aw2
Hi, it sound likes a belt. Some amana washers take 2 belts,1 for the spin,and 1 for the agitate. or some models spin rite of motor,and a belt for agitate. hope this helps. :)
Jul 07, 2009 | Amana ALW895 Top Load Washer
Ihave an Amana washer model DLWRAW. Ithas a
not a good number go to whirlpool parts surplus dot com and ask for mark i can get you going on that with a great price shipping is only 4.95
Jun 25, 2009 | Amana DLW330RA Top Load Washer
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Nov 22, 2008 | Amana NAV2335A Top Load Washer
Amana washer not agitating and does not spin all the time
"Its not spinning well" that means it is spinning but at a relatively low speed .....if this is so try having the motor serviced.....or replaced.......also have the capacitor checked...
Nov 10, 2008 | Maytag PAV2300 Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Smoking washer Amana NAV8800AWW
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
May 27, 2008 | Amana NAV8800E Top Load Washer
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
116 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
