Question about Pioneer VSX-43TX 7.1 Channels Receiver
Need a manual to download for pioneer VSX-43TX
If power failure, receiver needs to be reset each time to get sound from DVD/LD, otherwise, DVD player sound comes through TV mode
  • 130 Answers
Pioneer is really good about providing pdf manuals just google pioneer electronics ltd
Posted on Feb 10, 2009
I have a Pioneer VSX-D308 reciever and I have... no idea how to hook it up to my big TV (bought receiver used). Do I need the red/white cords? Do I need other cables? HELP! Wanting to hook up to big...
What your unidentified TV >>requires<< is the BEST Video from every video source. That would be the DVD, SAT Box. It probably has multiple high-end video inputs, right?
What your receiver needs is at least a basic composite video connection to the TV so you can set it up and manage it.
A web search for "Pioneer VSX-D308 manual" will find the manual.
ALL of the BEST Audio should go directly to the Pioneer. That includes the SAT and DVD player.
Your TV can exist just fine with basic audio from the video sources. And you could still watch it/them without the Pioneer turned of if you want.
I can't find the exact manual for free anywhere but if you download something similar like http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/ it should give you the basic guidance you need.
I recommend
Do some web searching for what the cables are for. It's all basic and standard.
Sep 07, 2011 | Pioneer VSX-D308 Receiver
I was using my vsx D510 with a hiteker dvd player
Each digital input is assigned a name and a function by you. You have to dig out the manual and assign the digital inputs.
My $.02. Why do you not want to use the coaxial imputs? There is no functional superiority of one over the other BUT coaxial is a) cheap, since it uses standard RCA cables; b) adaptable, since you can splice or split them among two devices; c) not delicate or prone to failure due to tight bends. I share one coaxial input between two digital device with an RCA splitter cable. Just have to make sure to turn the one I'm not using OFF. Try that with optical.
Dec 21, 2009 | Pioneer VSX-D510 Receiver
No TV sound, only DVD and CD players
Check your tv settings may need to change from speaker out to line out.
Check the tv input on the receiver, put the cd or dvd cables into the tv input. If you get audio the receiver is fine. No audio check the receiver settings.
Nov 16, 2009 | Pioneer VSX-54TX Receiver
DVDLD stuck on defaualt setting
There is a signal select switch witch if depressed will change the dvd/ld switch back. give it a shot.
Jan 29, 2009 | Pioneer VSX-D411 Receiver
Lost sound for DVD player
PRESS THE SIGNAL SELECT BUTTON THAT WILL ACTIVATE THE 5.1 SURROUND. IT WILL CHANGE FROM ANALOG TO DIGITAL OR DVD/LD TO DVD 5.1.
Jan 05, 2009 | Pioneer VSX-D411 Receiver
Improper equalizer between VSX-49TXi and LD player,no sound now
You may want to buy the service manual (SM) from Pioneer for this unit. It has a lot of info on resetting and testing the receiver under the "Test Mode". It is highly improbable that you could ruin the firmware by connecting the receiver in an unusual way. You may just need to reset it to factory specs. Another option if you bought it from a local Pioneer dealer is for them to reset. It usually involves getting into the secret menu to do so.
I had one of these for a short while and they are quite nice receiver.
Good luck
Dec 22, 2008 | Pioneer VSX-49TXi Receiver
Vsx-d511 digital coax input
in dvd menu cheak output audio settings whats it on pcm or bitrate 5.1 ? how sthe cable cond does it work on other coxal units
Jan 07, 2008 | Pioneer VSX-D511 Receiver
No DTS sound / RESET
Hi I have a Pioneer VSX D908S which is basically the same amplifier as yours with the difference that the one I have has no THX certification, as a matter of fact the service manual is the same, and mine has the same problem. The prblem is located in the DSP board, if you are able to remove the bonett, you will see on the right side a metal cover, remove it, once you have removed it, look for a IC9374 it is located, -looking this board in front to you- almost at the left upper corner, this IC has the PDK042A on it, with a soldering iron resolder this circuit. This is common problem with this pioneer amplifiers, and this procedure not always works, the final solution is to buy the DSP board but it is expensive. Good luck! Miguel
Oct 05, 2007 | Pioneer VSX-27TX Receiver
Video input not recognized for LD and DVD
By coaxial, do you mean the composite (yellow)? Either way you have to use the same style no matter what the cable. I mean, if you have s-video's IN to the reciever then you need S-videos OUT to the TV. ....Component IN to the reciever? then Component OUT to the TV. And so on. You cant have composite cords going into the reciever and use a component cord out to the TV (with the exception of a few models).
Sep 10, 2007 | Pioneer VSX-D912 Receiver
Pioneer VSX-43TX 7.1 Channels Receiver Logo
278 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
