Nokia N75 Logo
Posted on Feb 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia N75 always showes no signal on any band
The camera, music player, both displays, and all the menus and buttons work but there is no signal so I can't use the phone. I put my sim card in another phone and everything works fine. Help!!!.
Note: out of warranty
Jalal Sordo
Level 3:
  • Nokia Master 1,800 Answers
  • Posted on Feb 10, 2009
Jalal Sordo
Nokia Master
Level 3:
Answers
1800
Questions
Helped
590116
Points
5194
The Networ Ic is defective a check and replace is required in this case!!
What modem are compatible for n75 db dual band N router
Any modem should work; the modem is the device that provides a signal to and from the router. I have never run into any compatibility issues for a signal TX/RX device.
tip
Tips & Review on Nokia 5300 XpressMusic
Nokia 5300 is a great music phone,but it can be regrated on that the battery life is so short.So I've come up with this tips and tricks that can help you save some juice out of your phone.Love the loudspeaker but don’t abuse it so much it might become unfunctional.Don’t set the volume to the maximum level when playing through the loudspeaker.I found the radio better and clearer when playing through the loudspeaker than the music player because the loudspeaker omits more treble than the bass.
Camera Tips:
1. Always set the NIGHT MODE option especially on night shots
2. Set the White Balance to Daylight – When outdoors (Day) Fluorescent – When indoors
3. For acceptable shots, set the resolution to 800 x 600.
NOTE: Using the camera will put up a big drain on your battery.
Battery Tip:
- Don’t always use the camera. Only when needed.
- Set Packet Data Connection to When Needed. Setting can be found on Settings>Connectivity>Packet Data
- Always turn on the Power Saver Feature.
- Turn off your Bluetooth when not in use.
- Turn off screensavers (These are only battery wasters)
- Always make sure that the phone has adequate signal. (If the phone is searching for signals, it drains a big part of the battery)
- I know its fun to play games, but it can decrease your battery so fast.
- The best of all,carry an extra battery if you’re a heavy user.
I think this tip can be helpful. Thank you Everyone.
My nokia 5220 always shows not enough memory when i go to music player
just flash the mobile and it will be solved meet a local repair mechanic he will fix it for 200 rs
Not working always show "turn thepower off and on
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
·Turn off the camera.
·Remove the battery pack.
·Press and hold the power button for 30 seconds.
·Allow the camera to remain without power for 60 seconds.
·Reinsert the battery pack.
·Turn on the camera.
Also try initializing the Camera if you're able to access the Menu items on the Camera. The Initialize option will be available underSetup or Main settings Sub Menus.
If the issue persists again, service is required. Pleaseclick hearto locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Have to unlock my phone N75 sir!!my imei number is 354815013034536
To Unlock it from Network Lock get the Unlock code from
www.theunlockspot.com
Nokia N75 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia N75 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia N75 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia N75 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N75.
3 - Compose #pw+CODE+1#.
4 - The Nokia N75 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N75 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia N75
May 25, 2011 • Cell Phones
9helpful
3answers
Saving a sound track sent by bluetooth to my music player
It's probably a little late but yeah.Go To Menu>Music Player> Options> Refresh Library and hopefully all the songs you have in your inbox should transfer to the Music Player under All Songs. hope this works.
Unlock particular website from N75
you might have the restiction setting, undo it
93helpful
7answers
Nokia N75
hi..first press the menu button and then the * button
Top Nokia Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
