SOURCE: My Lenovo 3000 N200 is not responding at all, even when I press power button for 4 seconds and more
do one thing remove your battery from the your laptop after some min you put it agian in the laptop and solve the problem .
second think is that if the problem is not solve then go for other battery.
SOURCE: I formatted my lenovo 3000 N200 LAPTOP.i
go to the sound option in controll panel check if your device is working correctly or not .. there is a big chance that it might not if using vista or windows 7 then login as administrator and then install the driver again...
SOURCE: Avast! BART CD vs Lenovo 3000 n200
You will likely have to go through and create another boot disk, but this time, include the drivers that are going to be needed for SATA and your NIC. I have used an older version, but you should be able to include the drivers, and auto install / config then reburn the CD.
SOURCE: lenovo 3000 n200 0769AMU press power
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard that usually cause this issue. I wrote a tip on how to do the power drain. Try to plug in external monitor on the VGA port and see if you are getting display using external monitor. If you are getting display using external monitor then the problem would be the laptop LCD. If you are getting the same black screen using external monitor then the problem is already the motherboard.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
