Question about LG WM2432H Front Load Washing Machine
LG WD-3243RHD Front Load Makes grinding, crackling noise
i've had my All in one LG WD-3243RHD Front Load for almost 2 years, and one day i come home my clothes are soaked. I drain the washer/dryer and run the load again, after it fills with water, it starts to make a grinding,crackling noise!! and after awhile it cuts off and there still water in the washer.
any thoughts? LG WM2432HW Front loader
it stops mid way in cycle and displays oe and won't work after that
    President:
  • 1,902 Answers
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Posted on Feb 10, 2009
User manual lg wd-e52wp
try this site http://www.manualsonline.com/
Feb 27, 2011 | LG WD-3243RHD Front Load Washer / Dryer
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
I have an LG WD 3243RHD washing machine/dryer combo and it is displaying LE. Is there anything I can do without calling a repairman?
LE on this machine indicates a motor error. The connector in the lead wire assembly is not connected to the connector of the stator assembly. You need to reconnect or repair the connector. Also, it could mean that the Hall Sensor is defective and you may need to replace the Stator Assembly.
Nov 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
LG privilege WD-3243RHD User Manual
Find out where in your area it was sold and phone or ask salesman for Manuel or instructions they will be glad to help.
Jan 22, 2009 | LG WD-3243RHD Front Load Washer / Dryer
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Grinding noise
if the tub spins freely with no power on and makes no noise, chances are the problem is coming from the hall sensor (sensor assembly) which is located on the stator. The part costs around 20$ the part number is 6501KW2002A
Sgt 48
Jun 19, 2008 | LG WD-1280FHD Front Load Washer
LG WD 3243RHD
The crackling noise you're hearing is something is inside the drain pump and hitting the obstruction.  It's possible that the drain pump has been severely damaged to the point that the pump will have to be changed.  You will need to have a qualified LG technician diagnose the problem.
May 06, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Feb 11, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Can't unlock door!
Press "end of cycle", & wait for click or 2 minutes before trying the door. Would be good to get the exit hose off the standpipe to let the excess water flow out at floor level. Do not force the door.
Jan 23, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
811 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
