Question about Sony KP-51WS500 51" Rear Projection Television
HiDef receiver If i get a HiDef receiver from my sattelite company this tv is compatable isnt it
    Scholar:
  • 150 Answers
Hi, yes it is, video-tek
Posted on Feb 10, 2009
How do i set up my LG43uh620v smart 4ktv for sattelite reception.i have a sattelite dish ariel plugged in?
Easiest way would be use the HDMI output from your Satellite Receiver box to your new TV. If you don't have a Satellite Receiver box at that location, you'll need to get one from your service provider.
Your TV will not interface directly with the dish - you need the equivalent of a cable box to decode the signals from the dish, select channels, etc.
Apr 22, 2017 | Televison & Video
I have a hisense 50H5G and i cant figure why it wont go to 1080. Its says 480 and i have a hdmi cable and hidef channels. Please help
Try to change from your HIDEF output setting from 480 to 1080 if output from HIDEF not proper then your TV also not work at 1080
Jan 25, 2015 | Hisense Televison & Video
Record hidef films to media without computer
You should first ensure that the TV support video and audio OUT!
This will determine what connectors yo have available. Most connections will be for video and audio IN. You may have one connector for video/audio out which you can use. Chances are this will NOT be HiDef.
Nov 05, 2009 | Computers & Internet
I have Dish sattelite and it won't work with memorex under cabinet. They said I need a cable box in between the dish receiver and the tv. Why is this?
You need a receiver for each TV you want to receive the reception on. Your dish receives the broadcast signal from the network and your receiver decodes and recodes the signal to view on your TV. The companies have created their own proprietary equipment to accomplish this to keep anyone and everyone from simply installing their own dish and receiving all of their broadcast channels for FREE. In the olden days when satellite and cable TV was new, that is exactly what people did. Remember those gigantic dishes some people installed in their yards? They would intercept the signals coming from the satellites and hook up directly to their TVs. The companies got smart and started to scramble the signals going up to the satellites to make these home owner dishes obsolete. Because the signals are scrambled, you now need a receiver to un-scramble the signal. I hope this helps and good luck. Please remember to vote d368a18.jpg if you found this helpful. Thanks.
Oct 31, 2009 | Memorex MVUC821 8 in. Under Cabinet TV
Picture not as good as i expected
First, did the satellite company install an HD receiver? Second, are you using either component or HDMI cables from receiver to TV?  Still there are two factors that would produce your problem.  1. Color calibration 2. Signal strength
Proper color calibration is what makes SD actually GOOD on HDTVs. Low signal strength will create  a slow data situation. Slow data will not provide enough information per second for the TV to display a complete, error free picture so your TV has to interpolate or "guess" what colors should go in the pixels that it didn't get the data for.
Feb 16, 2009 | Philips 42PFL3603D 42 in. LCD TV
No HiDef on projection TV
u need a hd receiver to get hd on this tv. satellite or cable box. the screen blank in and out on hd signal. get use to the blackout.
Nov 15, 2008 | Hitachi 43FDX01B TV
No video
I am not sure if you have gone into the Receivers Menu or not? If you have NOT! Then please try this: Go into the Receivers Menu (If you do not see the MENU on the TV you can hook up a Composite (Yellow) Cable from the Receivers Monitor Out (Yellow) and select the Input on the TV that you plug into) Look in the Menu for Inputs or In/Out Config. or Video Setup. Look for the Input that you are using for that Device. Change the Video setting to HDMI. I also recommend doing this for you Audio as well. Find the Audio Inputs and MATCH each Input to there DEVICE and CABLE (Connection) Being used. Also check in the Receiver Menu for UPSCALE or UPSCALER. Turn this on or off to see if your TV is Compatible! Hope This Helps! P.S. Check the Manual for Upscaling Capabilities NOT all Receivers upscale and route the SAME!
Jan 12, 2008 | Yamaha RX-V861 Receiver
SAttelite help!
Unplug the satellite receiver for a minute or two especially if your connections are right.
Jan 02, 2008 | Apex Digital AT2702 27" TV
Sony KP-51WS500 51" Rear Projection Television Logo
23 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
