Question about Craftsman Garden
Steering gearbox I have a cox rideon stockman mower and the crown or pinion has stripped in the steering box, are there any details available as to where to start to dismantle and replace the parts
  • 1 more comment
  • ken_griffin Feb 12, 2009
    I have resolved this problem myself, but here are a few tips !
    1. After dismantling the steering wheel and dash, you will find that the steering gear box is unable to be removed as the securing bolt cannot be removed due to a lack of distance to withdraw it.
    2. The dash support panel (which stops withdrawl of bolt) is rivited to the steering column support.
    3. Grind off both rivets holding this in place, drive the rivet studs out and you can remove the bolt.(you can replace the rivets with bolts)
    4. The steering box can then be dismantled.
    5.If the crown wheel of the pinion (as in my case) has begun pulling over the square shaft, place the body assembly back in place and clamp the crown wheel back into position.
    6. Drill a hole through the (plastic) body of the crown wheel and shaft.
    7. Now before you reassemble you can either leave the large "plastic" screw ring off, or cut the centre of it out to accomodate the bolt you need to put through the hole you have drilled.
    8. Put a bolt through the hole, put everything back together and Bob's your uncle!
    Hope I have helped someone else out with this?
    Just wish more of the harder wearing parts were made of metal!
    XCheers Ken G
  • Eric Burnett
    Eric Burnett Jan 05, 2015
    I used a jubilee clip and it worked as a temporary fix - it went onto the bottom of the box where the shaft comes out.
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 858 Answers
PartdsTreeRepairClinic will help
Posted on Feb 06, 2018
  • Clyde Ottaway Feb 06, 2018
    Or try SearsPartsDirect
MrRodneyLong
  • 68 Answers
SOURCE: How hard is it to replace rack and pinion on a 1992 Toyota celica
well since you are asking its going to be kinda hard for you because you havent done it before. do you have another car to drive? do have help. It will take you almost all day if this is your first time and you take your time and be careful. you will need some good jack stands, something to catch the old fluid into and dont reuse the fluid!! there are severl steps to keep you from messing up the alignment of the car, tak my advice, buy a book and read it before you start on the car. Let me know MrRodneyLong@gmail.com
Posted on Jul 04, 2008
EarthJam
  • 23 Answers
SOURCE: removal of rear wheel on cox stockman ride on mower
These wheels are usually just held on with a Key way, ALOT OF TIME they offer resistance because they are rusted insode the rim and are needing a mallet to hit them from the inside pretty hard.
Turn it as you can usually a lever on the back side of the mower can be pulled out without the brake on to slip the transmission into nuetral. Turn the tire. I have used a small peice of 2x4 as well because a hammer dont fit well. Good luck I will watch this post and search my Diagrams to see if i have this rider tmrw at work.!
Posted on Feb 03, 2009
johnthejag
  • 286 Answers
SOURCE: Must add power steering fluid every two days.
Hi
Yes you can replace the steering rack rubber boots OK.
But if you are loosing fluid, it sounds like the internal seals are leaking, allowing the fluid to fill up these boots, and subsequently bursting them, so you will be back to square one.
Better to fit an exchange steering rack !
Good luck !
A FixYa rating would be Nice !......... Thanks.....John.
Posted on Feb 16, 2009
  • 133 Answers
SOURCE: cub cadet LT1018 won't start or crank
It might be a saftey problem. But before you start changing swithches or whatever try this. If you have to lift a lever to engage the PTO for the blades try wiggling it up and down a little bit while sitting on the tractor and the brake pedal depressed and turning the key to start it.
Sometimes there is a little wearing and it won't be in the right spot on its own.
Good luck and let me know if this helped.
roundo4
Posted on Aug 08, 2009
Dolfoff
  • 148 Answers
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
Do i need to replace fuel tank if rubber grommet has come out
cant find a picture of a cox ride on mower fuel tank
should be able to buy a grommet to do the job
mower repair shop first stop
Nov 05, 2016 | Garden
How do I remove the steering wheel from my 13hp cox stockman mower, tried putting upward pressure while hitting shaft with dolly and hammer with no success
There appears to be a roll pin up under the steering wheel that holds it on the shaft. You will have to tap this out with a small punch or nail before you can remove the wheel.
Feb 23, 2015 | Garden
Steering play
it is called a steering box not a gear box and the adjustment will be in the steering box or in the rack and pinion
May 13, 2017 | 2004 Cadillac Escalade
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
My L130 will not turn right.
you will need to change the steering gear , and the steering pinion and its not a bad idea to change the gear pivots (2) and also the bottom steering wheel shaft bushing. they sell a complete kit on ebay that has it all in one nice n tidy kit.> http://www.ebay.com/itm/JOHN-DEERE-STEERING-GEAR-REPAIR-KIT-102-135-LA120-LA155-/261112192757?pt=LH_DefaultDomain_0&hash=item3ccb7fdef5
dont let the high price full you, just the pinion $40 and the steering gear $32 is $72 and you get both and the $10 bushings x2 plus for the same price!!
Apr 24, 2012 | John Deere 22HP VTwin 48" Riding Mower
Power steering goes out intermittently. Had the steering column replaced 4 years ago now the problem is backm dealer said I may need new gearbox. And column replacement @ a cost of 1700.00
I dont think this car has a gear box,did you crash on that car to need to replace the steering column,you need to check first if the power steering pump has enogh pressure,the other part you need to check is the rack and pinion.
Oct 20, 2010 | 2004 Chevrolet Malibu
Sounds like the sterring wheel is striped
Sorry I don't have a solution but have a similar problem. I replaced the steering pinion gear in hopes that would resolve the problem, but it didn't. The steering pinion gear is located at the bottom of the steering shaft and turns the steering gear. Looks like the steering gear needs to be replaced as well. The nuts securing the steering gear are accessible in the same area as the pinion steering gear. I am going to order a replacement steering gear and attempt to replace it.
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
What kind of power steering is in a 2000 dodge Durango? and does it have a gearbox?
Starting with the 2000 model year, Dodge Durango's had what is called rack and pinion steering. It does not have a gear box.
The Chrysler racks are leak prone as well as known for having issues. What type of problem are you having?'
Apr 06, 2010 | 2000 Dodge Durango
My steering wheel just "free-wheels" I have lost all steering capibilities.
sounds like a bad "Rag Joint ', that;s a piece of tire carcass material (a two inch circle at the bottom of the steering collumn) where the steering wheel connects to the rack and pinion(It;s to kill vibration)
It's fairly easy to replace, also easy to get your steering wheel upside down
if the rag joint's good the steering rack and pinion assy must have a stripped gear.
This is rare, check the rag joint firstit's a small ***** to replace but not impossible usualy you have to unbolt the collumn inside the cab (Two bolts under the bottom of the dashboard, there's a cover to remove beneath the stering column)
Sep 13, 2009 | 1996 Ford Ranger SuperCab
Chrysler Voyager 2001 - Gearbox
that van does not have a gear box it has a Rack and Pinion gear that run off of Power steering fluid.
Jun 10, 2008 | 2001 Chrysler Voyager
Garden Logo
530 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
