Question about Microsoft Office Professional 2007 Full Version for PC
No available fields in form wizard
I am trying to create a form for a table using form wizard in Access 2007. The table has several fields in it, but when I click on form wizard, there are no available fields for me to choose from (the box is blank). I cannot figure out how to make the fields visible to the wizard.
  • prince gaffar Feb 12, 2009
    plz help me 2 solve diz pro & from where 2 install ms office
  • Gerald Russell
    Gerald Russell May 11, 2010
    the table is not listed in the dropdown "Tables/Queries" shown on the first screen of the forms wizard?
  • 25 Answers
If you select the correct table from the drop down, the fields should be shown in the box. or keep the table open and try creating form. or create a blank form and on the right side you will get tables and fields, you can just drag and drop required fields
Posted on Aug 22, 2009
Can u plz mail me tha easiest way to use Ms Access, like Creating relationship, with the table, creating form, query etc.
In general you initiate this process by pressing the "Relationships" button on the MS Access toolbar. It is the button with three small boxes arranged in a triangle shape.
When it first comes up it will give you the option to add tables. You can add any set of tables including the possibility of adding one table more than once (you would do this if you wanted to create a relationship between fields in the same table).
Once you see the tables you're interested in, you simply drag the field from one table over a field in another table. The fields should be those that will define the relationship. Once done, you should see an Edit Relationships window. You can get back to the Edit Relationships window later by double clicking the line in the relationships window.
MS Access does a good job of figuring out the relationship type. For example, if you match a field in one table, that is not a key, with a primary key in another table, Access will make this a Many-to-One relationship.
This can become a very deep subject. Hope this at least gets you in the right direction.
Dec 18, 2010 | Microsoft Computers & Internet
Want to populate a form with data from a table, the Id number is keyed into the form and once it's matches with the Id in the table I want the other fields on the form to be populated with the data from...
Create a Form from the main table with a subform based on the other data you will want populated. You put the fields in the subform that you want populated from the main form. Go to the properties for the subform and select the data tab, In the data tab, select the Link Master Fields and choose the field you want linked. When you type the ID number in the main form, the other firlds you have in hte subform should populate from the data inthe table.
May 14, 2009 | Microsoft Access 2003 for PC
Application and example of relationship in access
Relationships
After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
Having met the criteria above, follow these steps for creating relationships between tables.
  1. In the database window view, at the top, click on Tools ---> Relationships
  2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
  3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
  4. Select Enforce Referential Integrity
    • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
    • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
  5. Click Create and Save the Relationship
Apr 09, 2009 | Microsoft Computers & Internet
Data From Table Auto Fill
You need to create 2 tables. Create one table with just the Center Number, County and Center fields, using the Center Number as the primary key, lets call this table Center. Then create the other table with all the other fields you need, lets just call it the Main table for now.
Then create a relationship between the Center table and the Main table using the Center Number for the relationship. The relationship should be a One-to-Many from the Main to teh Center table. When creating the form, you take the fields from both tables. When you input the Center Number, the County and Center should be automatically filled in.
Apr 08, 2009 | Microsoft Office Access 2003 (077-02871)...
Connectivity between HTML page and Ms-Access
<HTML>
<BODY>
Set MyConn = Server.CreateObject("ADODB.Connection")
MdbFilePath = Server.MapPath("sample.mdb")
MyConn.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
SQL_query = "SELECT * FROM Friends"
Set RS = MyConn.Execute(SQL_query)
WHILE NOT RS.EOF
<LI><%=RS("Name")%>: <A HREF="<%=RS("Link")%>">Homepage</A>
RS.MoveNext
WEND
</BODY>
</HTML>
Nov 11, 2008 | Microsoft Office Standard for PC
Wizard unable to create form
i had this problem and it was because a computer class was installing multiple kinds of access on one computer. they wanted to teach all of them, but are now screwing them all up. ha.
Nov 10, 2008 | Microsoft Office Professional 2007 Full...
How to use passwd character in a table in ms-access 2003
When you create table where you want to store passwords, go to Edit Table, then select a field where the password will be stored, go to Input Mask field in Properties and type Password in that field. That will set up the field needed for storing passwords.
Aug 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Access 2007 forms wizard
If you run a repair install of office 2003
Jun 04, 2008 | Microsoft Office Professional 2007 Full...
How we can create Forms & queries in access
For forms, open a data table in view mode, while there locate the forms setup wizard. For your first try just answer the questions the best you can for the wizard. When there are no more questions to answer wizard will create a form for you. From what you learn doing that you may get enough hints to make a form from scratch. Just keep in mind you always build a form from the fields in a table.
Now for the Query, start out the same way and use the wizard. Query to most folks means ask a question and get an answer. In access query is a way to present sub sets of data or ways to modify data in the fields of your tables.
Jun 03, 2008 | Microsoft Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
121 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
